    Name of component
    4 Posts 3 Posters 307 Views 3 Watching
    • F Offline
      fred2420
      Hi i am struggling with what i am sure is something really easy but after hours of search i can't work out how to get the name of the active component as a string. I can set the name in Component attributes.
      This is what I've tried
      model = Sketchup.active_model
      selection = model.selection.name
      but its no where near
      Cheers in advance
      Fred
      • TIGT Online
        name = model.selection[0].name
        BUT of course that assumes that the first object in the model's selection has a 'name'. A ComponentInstance or a Group might have a name [BUT it might also be ""], AND many other things like a Face or Edge never will have a name, so you'll then get an error...
        If [as I suspect] you want the name of the component-definition of the first item [component-instance] in the current selection... AND you know it is definitely a ComponentInstance then you can use
        name = model.selection[0].definition.name
        which will return the unique string that is that component-definition's name.
        To stop errors you really ought to test for the selection's suitability, 'type' thus...
        sel=model.selection
        name=nil
        if sel and sel[0] and sel[0].is_a?(Sketchup.ComponentInstance)
          name=sel[0].definition.name
        This way name is either 'nil' or a string, so the next step in your code could be
        if name
          ### do something with 'name'
        else
          UI.messagebox("Please select a Component Instance to find its Name !")
          return nil
        • F Offline
          fred2420
          Nice one that has worked well cheers for the help πŸ‘
          fred
            Note that there is component instance name and component name. Component instance name is the same as a group's name.
