    [Plugin] Plugin Loader for SketchUp
    14 Posts 11 Posters 19.2k Views 11 Watching
      dylan
      Excellent work Alex and extremely useful πŸ‘
      http://dmdarchitecture.co.uk/
        Tested! β˜€
        Works like a charm! πŸ‘
        Why with your plug no necessary to restart the prog after loading a new plugin? 😲
        That is black & white magic πŸ’š
        Just why not a "free surf" on any Net's address ❓
        For goto Smustard.com for example? A Plugs famous place πŸ˜‰
        • MALAISEM Offline
          MALAISE
          I find it very useful and time saver. πŸ‘ πŸ‘
          Thanks Alex.
          MALAISE
          La Connaissance n'a de valeur que partagΓ©e
          • BurkhardB Offline
            Burkhard
            Nice one.
            @Pilou there is a script from the first ruby days, called script loader. Works in the same way.Not magical πŸ˜‰ You can find it at Didiers site.
            [http://www.ia-plus.de(http://www.ia-plus.de)]
            • alexschreyerA Offline
              alexschreyer Extension Creator
              Thanks for the comments. I actually didn't know about the script_loader plugin. But you're right - the underlying load function is very simple, nothing fancy here. I like calling it "Plugin loader" though because the menu is the Plugin menu and I wanted to make it easily understandable even for the novice user.
              @Pilou: I didn't include Smustard because the Sketchucation index seems to index their plugins and I wanted to keep the menu as concise as possible.
              Two questions for everyone:
              • Is there a way to turn on the navigation buttons in the web dialog? Apparently these are off in Windows by default.
              • Does this work on the mac? I haven't tested it yet.
              Author of "Architectural Design with SketchUp":
              http://sketchupfordesign.com/
              • Didier BurD Offline
                Didier Bur
                Hem hem, it seems I must update my site asap... πŸ˜’
                DB
                  Hi Didier, didn't mean to put pressure on you... πŸ˜‰
                  Cheers, Alex
                  • Jean-FrancoJ Offline
                    Jean-Franco
                    Dear Alex, thank you for this very helpful plugin.
                    I've copied all my plugin folder on my USB key.
                    I've no problem with the single scripts. But if I want to load JPP plugin I've a bugslat !
                    The message box ask me to install progressbar.rb. But it already exists in my plugin folder.
                    Any idea on what could happen ?
                    Jean-Franco
                      This is a case where my loader might not work. Some (especially the more complex) plugins have dependencies that are "hardwired". It might help to have the progressbar.rb script in both locations. Dito for other standard scripts.
                      • renderizaR Offline
                        renderiza
                        Thank you very much!
                        Before this plugin I had to close & reopen my skecthup to review the changes I made to my ruby script but now I can just reload it right inside the program.
                        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                        • gillesG Offline
                          gilles
                          I'm trying to manage my plugin collection, your plugin seems to be a good way doing it.
                          Halas, when I choose "load plugins from folder" select any plugin in the folder, I have this report in ruby console:
                          load"/Volumes/USB/as_pluginloader.rb"
                          true
                          Error: #<NoMethodError: undefined method as_require_all' for AS_plugin_loader:Module> /Volumes/USB/as_pluginloader.rb:164:in load_plugin_folder'
                          /Volumes/USB/as_pluginloader.rb:229
                          No plugin loaded. 😞
                            driven
                            @gilles
                            add self. at line 143, that seems to work here... [ in a quick test at least!!! ]
                              def self.as_require_all(dirname)
