    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Warp drive
    20 Posts 7 Posters 605 Views 7 Watching
      Starling75
      Now this is interesting.
      http://www.space.com/17628-warp-drive-possible-interstellar-spaceflight.html
      http://dvice.com/assets_c/2012/09/warpdrive_diag-thumb-550xauto-100812.jpg
      http://www.starlingarch.cz
      • iichiversiiI Offline
        iichiversii
        Yes that was an interesting read, so this is how our ships should look http://1.bp.blogspot.com/_KEArRUZspiA/SgYxA3S9JaI/AAAAAAAABOI/QPXKBwZxVZE/s400/warp.bmp
        Bring on the Rain...
        • MarianM Offline
          Marian
          Looks like the Vulcan ring ships. ๐Ÿ˜„
            iichiversii
            Strangely enough iv come across a few ships with this design ๐Ÿค“
            • MarianM Offline
              Marian
              I hope that when they build it, it will look like this.
              http://images1.wikia.nocookie.net/__cb20100805095945/startrek/images/b/b2/Enterprise_XCV-330.jpg
                iichiversii
                Omg Marion, that's just ugly, iv found ships in battlestar galactica, star trek, star wars and future concept art for future NASA spacecrafts all with a similar design ๐Ÿค“
                • MarianM Offline
                  Marian
                  The point is historical accuracy to Star Trek history, at least in ship design ๐Ÿ˜„
                  This is supposed to be one of the first ringships of Earth in the ST univers, but I will not be satisfied until they can make ships with nacelles. ๐Ÿ˜›
                    iichiversii
                    Ummm, don't know about that Marion, star trek was based in the future, the opening credits for starwars is always "a long time ago, in a galaxy far far away" in the past, I think jabba the hut had warp drive before captin kirk, ๐Ÿ˜†
                    • MarianM Offline
                      Marian
                      ๐Ÿ˜’
                      • EscapeArtistE Offline
                        EscapeArtist
                        Hmm. I think that the ring is pretty cool. While space faring vehicles that look designed for atmospheric flight are more pleasing to the eye, that shape is irrelevant in space save for the logic of reducing frontal area exposed to erosion and collision. A sphere would be just as suitable for space flight as a cube or cylinder. Atmosphere no longer being a factor, structural integrity, safety of the occupants, longevity and ease of repair become the overriding factors.
                          iichiversii
                          You know what, the design is kinda growing on me too, infact I might try and model it, but that's something I won't be doing for a while, interesting read, interesting ship, although they may know how the design should be it would be impossible anytime soon to create and store the energy required to manipulate time and space so we are still a long way off unfortunately ๐Ÿ˜’
                          • olisheaO Offline
                            olishea
                            You need the same negative energy equivalent to the whole mass of jupiter!! So I've heard...
                            oli
                              iichiversii
                              Is that all ๐Ÿ˜†
                              • MarianM Offline
                                Marian
                                Warp Drive May Be More Feasible Than Thought, Scientists Say
                                Faster than light travel may actually be possible using a warp drive to bend space around a starship. New calculations suggest such a vehicle would require less energy than once thought.
                                Space (www.space.com)
                                The only problem is, previous studies estimated the warp drive would require a minimum amount of energy about equal to the mass-energy of the planet Jupiter.
                                But recently White calculated what would happen if the shape of the ring encircling the spacecraft was adjusted into more of a rounded donut, as opposed to a flat ring. He found in that case, the warp drive could be powered by a mass about the size of a spacecraft like the Voyager 1 probe NASA launched in 1977.
                                Furthermore, if the intensity of the space warps can be oscillated over time, the energy required is reduced even more, White found.
                                301 Moved Permanently
                                (gizmodo.com)
                                The Eagleworks team has discovered that the energy requirements are much lower than previously thought. If they optimize the warp bubble thickness and "oscillate its intensity to reduce the stiffness of space time," they would be able to reduce the amount of fuel to manageable amount: instead of a Jupiter-sized ball of exotic matter, you will only need 500 kilograms to "send a 10-meter bubble (32.8 feet) at an effective velocity of 10c.
                                So 500kg=10m warp bubble at 10c so I wander if you need 5tons for 100 m bubble at 10c or either the speed decreses or you need more exotic matter hmm....
                                A 100m bubble could house a good sized ship.
                                  iichiversii
                                  What? ๐Ÿคฃ
                                  • MarianM Offline
                                    Marian
                                    What what โ“
                                    • mitcorbM Offline
                                      mitcorb
                                      e=mcยฒ The outcome of which is as you approach the speed of light, your mass increases accordingly, and therefore the energy required to continue.
                                      • MarianM Offline
                                        Marian
                                        Well yes, you can't go faster than the speed of light because your mass and the energy requeried would be infinite, but they are talking about bending space and time into a bubble around the ship and only that bubble moves faster than light while practically the ship sit still in the space in the bubble. Apparently for that kind that of thing you need some sort of exotic matter and you would need 500kg for a 10m bubble to be projected at 10c.....It would be something if it were possible.
                                        • olisheaO Offline
                                          olishea
                                          Well, we don't actually know. Scientists have controversially discovered particles which outpace light.
                                          oli
                                            Theoretically there's nothing 'wrong' with traveling faster than the speed of light.
                                            Just as in the same way there's no problems for us traveling slower than the speed of light.
                                            It's just there's a catch - at the speed of light you need infinite energy, have infinite mass, time stops etc... and if you are just 'near' the speed of light [either side] the effects are also quite problematical for your day-to-day life.
                                            This means that objects traveling very very fast on our side of the light-barrier can't readily accelerate without dire consequences, and in the same way objects traveling above the speed of light can't readily decelerate down towards the speed of light either.
                                            So ne'r the twain shall meet!
                                            We are talking about transporting information, as much as physical objects here...
                                            The 'alternative' idea of 'warping' space itself... so that an object has less of a distance to traverse in the same time-frame could have the same effect as traveling faster than the speed of light... but controlling the forces involved in doing this 'wormhole' [or similar] in a way that doesn't squish the traveling object so much that its information is lost, have not been worked out at all well!
                                            Since 'you' are going to be the most important bits of information in the object that is traveling this way, then your chances of 'you' still being 'you' at the other end are, at the moment, very slim...
                                            Also, let's say you did successfully go one way down this 'tube', then how would you return ? Any given 'wormhole' is probably going to be transitory and difficult to fine-tune in where/when it ends up at all, let alone doing it in the exact 'reverse' way - so you might easily arrive back before you left or return long after you departed, either way this would not a satisfactory result...
                                            Unfortunately 'Star Trek' et al is/was made with little basis in reality...
                                            Although I really do hope that someone somewhere manages to sort out this seemingly insoluble issue... I won't be one of the first volunteers... ๐Ÿ˜ฎ
