    What's this?
    65 Posts 15 Posters 4.0k Views 15 Watching
      Great idea... though I think as you drew it the 'down' support locations might clash with the chairs under etc...
      However, it could be the basis of a neat solution...
      Perhaps a two-step lift...
      You raise the table higher that its 'up' position and the supports lock in place at their bottom ends, then the top ends of the supports slide out to lock in the top in its 'up'...
      Perhaps along these lines ?
      TableLegSliders.skp
      • Mike LuceyM Offline
        Mike Lucey
        Think we are getting somewhere now πŸ‘ Probably could do with Dave R for comment as wood can be tricky at times πŸ˜’
        • hellnbakH Offline
          hellnbak
          How about simplifying this thing and eliminating the sliding seatback altogether?
          Personally I find this version much more inviting and less utilitarian. It has the added benefits of using less material and easier construction.
          No, actually they fit quite nicely under there in the lowered position.
          This isn't finessed and needs a lot of tweaking but you get the idea
          • hellnbakH Offline
            hellnbak
            Just noticed that the piano hinge on the back of the chair is not where it should be. I raised it when rotating the seatback support and forgot to lower it again. Sorry about that.
            First mistake I've ever made πŸ˜‰
            • hellnbakH Offline
              hellnbak
              One observation - I don't think any of these ideas would ever qualify as a coffee table. Way too high, and too big too.
                I have a coffee-table that's bigger in plan, although a few mm lower...
                PS: Love the new idea - without the plumbing ! "
                • hellnbakH Offline
                  hellnbak
                  Really? It seems awfully high to me, and it seems like it wouldn't work in the average home, overall size-wise. Only homes with larger than average size living rooms. But whatever, the fun is in the designing.
                  Thanks.
                  No plumbing??? 😞 Would be really convenient. Maybe as an option?
                  • hellnbakH Offline
                    hellnbak
                    I was also playing around with the idea of a spring in the base to make raising and lowering easier. Any thoughts on this?
                    • cheddaC Offline
                      chedda
                      I saw this and thought of you ! Gotta say it's pretty tight.I like the fact it is asymetrical perhaps this is an avenue no one here has been down.
                      (www.facebook.com)
                      PS i don't see it on their main site, anyways both the facebook link and their home page are pretty design centric for us 3D nerds.
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                      • hellnbakH Offline
                        hellnbak
                        (www.facebook.com)
                        Interesting, Chedda. But they main point of this thread is to design something that can be converted from a coffee table to a dining table, requiring it to be raised and lowered
                          Mike Lucey
                          Interesting FB site.
                          • hellnbakH Offline
                            hellnbak
                            Hey Mike, you never did say what you thought of my non-sliding seatback solution.
                              Mike Lucey
                              The project in on the shelve at the moment but I will take it down and play a little more over the weekend. Thanks for you input, its been very helpful.
                              • cheddaC Offline
                                chedda
                                Oh i see hell n back that is a tall order. If its just a coffee table without chairs it's do able. Otherwise both the chairs and table will have to extend. Perhaps telescopically.
                                • 4 / 4
