    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    How to make a spool/spiral
    11 Posts 4 Posters 1.9k Views 4 Watching
      rumcajs
      I need a tip how to do this.
      I want to create just a very simple spiral, with 3 or 4 winds/wraps. I am not interested about the holder itself. Maybe is there some plugin for creating spirals?
      I have seen this tutorial but I would like to use the spiral starting at point 0:38
      http://www.youtube.com/watch?feature=player_embedded&v=H1IO2f1xvd0
      It looks like sinus but how to draw this sinus (it is 3D sinus, not 2D)? The next step of scaling and coping of the "sinus" looks simply.
      • daleD Offline
        dale
        There are lot of Forum threads on this. Use the Forums search tool under "Helix", and quite a few will come up.
        http://forums.sketchucation.com/viewtopic.php?p=344360#p344360
        Here is one. Hope it helps.
          Else drawx Helix by Jim Foltz is the key for all Spirals ๐Ÿ‘
          for any curves 2D 3D curves : Draw Metal ๐Ÿ‘
          And for draw spiral by hand : use the Arc Circle with Blue of South water : that want say that arc circle is tangent with the previous one ๐Ÿค“
          so beautiful 2D spirals too! ๐Ÿ˜Ž
            No he used not a Sinus function ๐Ÿ˜‰ (at 0.38)
            He just Double Click on the bottom segment! (because previous he made a very tricky Copy Move / * construction! )
            So all the touching segments are selected = a sort of sinusoรฏdal ๐Ÿ˜„
            Just weld them if you want with Recurve by Diggsey
            You can use this very useful plug inverse selection by Tig!
            So after the Double Click / Inverse Selection / Delete = you have only the "sinusoรฏd" ๐Ÿ˜‰
            This guy (?) is one of the better tricky guy (?) for funny constructions! ๐Ÿ˜Ž
            Study them you don't regreat that! โ˜€
            For some spiraloรฏds you can also use the Twist function Inside Fredo Scale ๐Ÿ˜„
              And of course this beautiful one ๐Ÿ˜Ž
              Same simple tricky construction than previous! ๐Ÿ‘
              By Kitto Raupp
              [flash=560,315:2nbhvsdf]http://www.youtube.com/v/pNTetL3Udkc[/flash:2nbhvsdf]
                rumcajs
                OK I think I found it how to do
                  rumcajs
                  That damn good tutorial. I'm glad I understand it. But will want to learn more later, how to create more beautiful shapes.
                  Ok, and If I created a tube from this spiral line, could I make similar lines on the surface of the tube? So it will look that the segments / springs are twisted.
                  Yet I did not find how to remove the spaces which are created between segments when you apply lines2tubes plugin. Do you know how to solve this? When you have the the spiral I want it to be tube.
                    You can use Pipe along a path by Tig ๐Ÿ˜„
                    Or sometime if the curve is simple The Follow-me tool with a circle perpendicular to the first segment ๐Ÿ˜‰
                    For put a circle ar anything perpendicular to the first segment use the tricky
                    Perpendicular tool by Chris Fuller ๐Ÿ˜‰
                    Not yet think of that but for a funny phone lines try this cool one By Sdmitch ๐Ÿ˜‰
                    Followme helix ๐Ÿ‘
                    I believe that you can use it for your question
                    Just take the same diameter than for your tube ๐Ÿ˜‰
                      rumcajs
                      I solved that. I had to create texture. I searched before but found none textures. All are with the damn watermarks or not symmetrical for SU use. So had to create one. Not simple job but I had a luck.
                      Note: The diameter is circle, not like real twisted object. If would like to do twisted object with 3 strings or so... hmmm. That is idea. But would be better if somebody would do plugin for this. You would just add three or more lines to one bunch. Than you would make it to be tube, add a texture... And then just twist them...
                        Like this one? http://sketchup.google.com/3dwarehouse/details?mid=81a297b052724f324a13dc5fc9a07d7c
                          rumcajs
                          Yes, something similar - if you mean the previous topic. In the last post I speak about 3 strings, like you have a phone cable, so there are 3 strings. Maybe I do not choose right words, English is not my native language.
                          But I think, I should try something. Fredo Scale has twisting tool. But I did not succeed to twist the tubes (paralel ones). I made a group of 4 pipes and tried to twist them. Should it work?
                          Edit: Once I suceed just a little bit. I exploded the group and selected all tubes. Then I twisted them, but just a little bit. Now I cannot succeed nor a bit. But I doubt that this tool would twist more times, like 9999ยฐ
                          Edit2:
                          So it is a kind of twist which is not possible to repeat more times. The object either de-twist itself or it get strange kind of twist, not like the wires of cable...
