    Making spheres and adding textures to them
    19 Posts 5 Posters 1.3k Views 5 Watching
      rumcajs
      If you make a component of one sphere and copy it that's run speed! ๐Ÿ˜‰
      With 24 segments you have yet a very cool sphere!
      I tried 2 spheres with 60 segments (one bigger, second one smaller and intersected) and made some component joining with Follow edges from LSS toolbar. But that was unable to finish that task (it stucked at 7%). Then I took only the little sphere and joined with some objects and it was faster, but still took few minutes. I cannot to send file because the att. is 4 MB.
        rumcajs
        Here
        http://sendfiles.org/syfoV
          Use http://www.sendfiles.org/ and send the adress resulting ๐Ÿ˜‰
            But 60 segments is not reasonnable for make some try with plugin under beta session! ๐Ÿ˜„
            12 segments is sufficient for this sort of sport!
            And why not in V6 : i can't reload it! ๐Ÿ’š
              So your works remember me this guy Orgelf here ๐Ÿ˜‰
              Maybe you can also use Line2Tubes by Didier Bur
              will be in the Menu Tool: Convert arc,circle, curve, line in cylinder :
              precision = number of segment section so 4 = a box, 12 = tube
              (a bit slow on my 10 years old computer ๐Ÿ˜„
              You have some wood textures in the native Paint Tool
              But texture at this size is quasi the same than a color ๐Ÿ˜‰
                rumcajs
                Line2tubes is great plugin. I look forward to test it. Will save a lot of work.
                  rumcajs
                  ok but how to remove spaces
                  http://i49.tinypic.com/2mgsbhy.png
                    rumcajs
                    I believe Nikola and me could use this plug-in for painting, texturing, not just spheres:
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=42089#p373073
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=44552#p397448
                    Thrupaint as part of Fredo tools.
                    Video here:
                    http://www.youtube.com/watch?v=l2QjLlUQVrY
                    It's awesome what various tools Fredo managed to develop! ๐Ÿ˜ฎ
                      Post an SKP File (Menu File/ save as V6) ๐Ÿ˜‰
                      It's impossible to answer with only an image! ๐Ÿ˜‰ (so many possibilities !
                      And how and what are you doing ? What function...
                      Yes True Paint by Fredo6 is fabulous for replace the native Texture Tools! ๐Ÿ˜Ž
                        rumcajs
                        I've just used circle + line2tubes as you recommended. This was just try with the plugin I just downloaded, but I see it creates spaces when you try to make tube from circle.
