    Smeg gas hob
    23 Posts 9 Posters 1.7k Views 9 Watching
      Crazy Eyes
      Hi all, I spent way too much time making this, so feel free to use it as you wish.
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      SketchUp
      Twilight Render
      Some people are lovers, some are fighters, if you love to fight, fight for love!
      • locoL Offline
        loco
        Thanks Lyall..very nice detailed model, much appreciated (btw nice render too!)
        Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
        • HieruH Offline
          Hieru
          Should come in really handy - thanks 👍
          You might want to take a look at the gas knobs as many of the faces are missing and need repairing.
          www.davidhier.co.uk
            Nice, thanks very much mate.
              Crazy Eyes
              Hi thanks, for the thanks.
              They are there in SU, but because it's rendered in Twilight, the opacity is set by the twilight material, which in this case is a dull semi-transparent plastic. The material is "Knob Plastic" in the materials.
              • HieruH Offline
                Hieru
                I see.....I wondered why you would lose faces at that scale.
                Thanks again for sharing the model. Siemens or Smeg are usually my go-to brands when it comes to hobs for kitchen scenes.
                www.davidhier.co.uk
                • mitcorbM Offline
                  mitcorb
                  Seems to me the supports for the pots and pans are a bit precarious. How is it in real use?
                  • MarianM Offline
                    Marian
                    Smeghead!
                    [flash=425,355:2fw7f1un]http://www.youtube.com/v/3A0RFDm8_rE[/flash:2fw7f1un]
                    • cheddaC Offline
                      chedda
                      Thanks for the model !
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                      • hellnbakH Offline
                        hellnbak
                        Really nice modeling 👍 , although I must agree with Tim that it would be too easy for a pot or pan to spill if it gets off-center too much. Also it seems like it would not be very energy efficient with the burners raised like that. If they were submerged in wells the heat would be much more concentrated on the cooking utensil, plus if the supports were flush with the surface the stove top area would be much more useful.
                        Just nitpicking (that's what I do) 😉
                          Crazy Eyes
                          @marian said:
                          Smeghead!
                          Thank you Marian for your helpful contribution!
                          As for the comments on the supports, I didn't design this, smeg did. I just built the model from photos off the internet. I guess that the four posts are sufficient. I did try to model the gas flames, but that was beyond my skill level.
                          Cheers
                          • MarianM Offline
                            Marian
                            You're very welcome. I love being helpful, it feels wonderful. 😄
                              Master chief cooking ! 😎
                              • mitcorbM Offline
                                mitcorb
                                @CrazyEyes:
                                Just for the record, I think your model and render are excellent.
                                • MarianM Offline
                                  Marian
                                  Some flames. They're probably a bit highpoly to be of use, but I just wanted to experiment.
                                  cooker flames.skp
                                  • locoL Offline
                                    loco
                                    Nice 'flame' model Marian, did you model three flames for the component or just one and scaled it to fit inside each other?
                                    • MarianM Offline
                                      Marian
                                      I initially just modeled a rounded cone, then copied it 2 times and scaled them to fit inside the first one. I then made them all a group and used the Radial bending tool from the Fredo Scale plug-in http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&hilit=free+scale to bend the whole thing up. I then just copied them.
                                      • hellnbakH Offline
                                        hellnbak
                                        Nice flames, Marian!
                                        (I got it down to 150kb if that makes it more useable)
                                        • MarianM Offline
                                          Marian
                                          Cool, any little big helps. Some people might have a lot of cookers to lit up and the number of the flames pile up fast. 😄
                                          Lyall I turned on the cooker for you. You can now make me a nice stew or something. 😄
                                          SMEG PVA 750 graphite gas hob.skp
                                          • locoL Offline
                                            loco
                                            Thanks for the explanation..good workflow...the hob has sprung into life now..very effective 😉
