    [request] Start Sketchup with activated Plugin
    4 Posts 3 Posters 432 Views 3 Watching
    • BurkhardB Offline
      Burkhard
      Can we start Sketchup in that way?
      http://www.ia-plus.de
        Yes.
        Now please explain what you want to do... πŸ˜’
        NOTE:
        If you had a tool activated by the code TIG.doit() in a file called TIG-doit.rb in the Plugins folder, then you can write a short script in the Plugins folder called say zzz_TIG-doit_activator.rb containing the [pseudo] code:
        require "TIG-doit.rb" TIG.doit() if Sketchup.active_model
        I named it with leading z's so that it auto-loads late on, in case any other scripts are trying also to launch their own tool at startup !
        If you wanted to launch a native tool then use something like:
        Sketchup.send_action("selectSelectionTool:") if Sketchup.active_model
        which changes the default 'Line' tool to become 'Select'.
        You could also add a couple of Observers to the Sketchup App... to redo this should the user Open or make a New SKP, when the .rb won't auto-reload...
          Trogluddite
          πŸ˜„ Thanks TIG. I've always been mystified why they chose 'Line' as the default tool - 'Select' seems much more sensible to me; so now I have made my first ever .rb file (though I think it will be 1000 years before there's any chance I'll rival you, ThomThom, Fredo et al.!!).
          • BurkhardB Offline
            Burkhard
            Thanks TIG. No need for me to explain this since I'm not a coder and this is all mystical for me.
            It was a question in general for an idea a client have.
            If they want me to realize, I will take a look for someone with professional background.
            Btw. I saw in the API the values for send_action. But, is there a list of AutomationID available? ( like save 57603 )
