    Match Photo and axis
    33 Posts 6 Posters 2.5k Views 6 Watching
    • beginnerB
      beginner
      Google SketchUp Techniques: Match Photo Part 1
      http://www.youtube.com/watch?v=fhzpqf7fywM
      Can you post the photo only - small would be fine - I would like to see the vanishing points/perspective.
      Regards, SU 'beginner'
        rumcajs
        I think this could unswer it:
        Top down view
        http://i50.tinypic.com/ehzq4p.png
        I drawn triangle instead rectangle and I see the base of the pylon.
        http://i46.tinypic.com/v6m78z.png
        The base is skewed
        http://i49.tinypic.com/nldkap.png
        Could it be because that I closed Match Photo window or does it not have effect? I had established axis before starting drawing.
        Axis here:
        http://i47.tinypic.com/6iwt4g.png
          rumcajs
          beginner, I have seen this video 3x times. You can download the file on first post, it contains the photo. Actually I am not sure where is the photo, coz there are many ones
          And see last images in my previous updated post.
          • beginnerB
            beginner
            I downloaded your SKP file and there is some small part of the photo.
            First comment - Your 'Match Photo' perspective is wrong...
            Definitely, separate photo would help.
            PS. You can see that the horizon is set in the wrong place and subsequently the whole 'Photo Match' would be wrong.
            The photo should be rotated (I would use PhotoShop) to a point where you have 'proper horizon'. πŸ˜‰
            • beginnerB
              beginner
              Step 1
                rumcajs
                Oh. Do it like so?
                http://i48.tinypic.com/2rzoyro.png
                Or more to right? The top is streight (almost), the bottom looks much more skewed.
                  rumcajs
                  Thanks. They are from one source. I probably printscreened it. One printscreen was from zoom and one from whole image. I dont remember.
                  Can you explain the image?
                  • beginnerB
                    beginner
                    Hi rumcajs,
                    Please wait - I will draw some main elements for the perspective...
                    Also, I don't trust the photos as it seems that they could be already assembled from two or more...
                    I have corrected the perspective in your SU file as well - have a look
                    pylon_beginner.skp
                      rumcajs
                      So can it be like so?
                      http://i49.tinypic.com/otogmb.png
                      • beginnerB
                        beginner
                        Looks better...
                        I did the perspective for the bridge - have a look.
                        It was difficult to judge the scale of a person in comparison to the scene based on your first photo...
                        Size adjusted - Now you have some good starting point.
                        moat_beginner.skp
                          rumcajs
                          Wait, I will check googleEarth to measure the distance
                            rumcajs
                            I recalled a plan that bridge (exactly level of the bottom of the door in wall) is in 10m above ground. There is shallow water in this area, so I think door bottom could be 9,5 m above water surface.
                            Check this - GE
                            http://i47.tinypic.com/24no4g1.png
                            • beginnerB
                              beginner
                              The perspective should be fine.
                              Adjust SU's object scale by dragging along the 'BLUE' axis when in 'Edit Matched Photo'
                                rumcajs
                                It does not seem as good as should be. I did it in detail. Open my file and check with Orbit the hand of the woman and the edge of pylon (the hand is just beside it). It is very big.
                                http://i50.tinypic.com/w2gmlj.png
                                pylon - start.skp
                                  rumcajs
                                  I've calculated 4 persons with 165cm height per height of the bridge. This should be correct:
                                  http://i50.tinypic.com/20ft6af.png
                                  • GaieusG
                                    This is not a good photo to use with PhotoMatch. There are hardly any distinctly visible vertical (and few horizontal) lines for reference, the photo was taken almost frontally of that bridge face (instead of from a corner - which I know would be hard here) finally you do not know if it was cropped therefore it's not trustworthy at all.
                                    Generally speaking: when you do a PhotoMatch, it will not do it to correct scale at all. You need to scale your structure after you made the PM and projected the photos - so do not even expect it to come out correctly first. All it does is adjust the camera angle and FOV to match to that of the photo. Moreover, it's "best" for those cubic, "blocky" buildings you can find in newer districts of towns but in older quarters, where hardly any building has right angle corners, it is practically useless.
                                      rumcajs
                                      Please, tell me how can I get 165 cm high figure/person in the image? I will go back to the yesterday's night project, the cut image was good, but needs to scale to fit with a figure.
                                        rumcajs
                                        Can you help with this? In Photo match I set the axis and draw this. Now I have the biggest problems to draw in depth. The engine often sugests blue axis when I try to draw in depth. Now I try do draw these three (red) lines:
                                        http://i49.tinypic.com/2wp05k9.png
                                        But I cannot to do it. I tryied many ways but alway it it either too far back or too far in front. The line is just few cm, maybe 4-7 cm, but this draw line 20-40 cm or more long. Terrible.
                                        So I try to draw it in 3D view instead 2D on photo, but it is the same result. The 2D view is verse coz I don't even see what happens - where the line goes.
                                        • BoxB
                                          Do us all a favour and learn how to use the basics of the software.
                                          It isn't possible to explain to you how to do what you want because you don't understand what you are doing.
                                          Learn from the many tutorials, draw some simple models then draw some more difficult ones then slightly more complex again etc etc
                                          Get a grip of the tools you are using and stop bashing away at it blindly.
                                          People will gladly help when they see that it is possible to help.
                                          • beginnerB
                                            beginner
                                            This is what I could get out of your photo.
                                            Don't draw the individual stones...
                                            Do few Le Corbusier's buildings to be more familiar with SketchUp.
                                            PS. Le Corbusier would allow 182.8cm per person πŸ˜†
                                            moat_beginner2.skp
