    Layout wishlist
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    84 Posts 24 Posters 47.7k Views 24 Watching
    • Lemoyne ArchitectL
      Lemoyne Architect
      @bmike said:
      And make the tools work just like in SketchUp
      I hate the way things work now. If I want to move something, I want to pick the object, then move it by hitting M.
      Same for copy.
      This - going back and forth where "T" is "tape" in SU and "text" in LO is almost more confusing than having "M" and such NOT work in LO.
      As others have said, would really like better tables in LO.
      • porch_unpluggedP
        porch_unplugged
        format dimension style
        be able to turn on or off sketchup layers
        speed it up!
        • GaieusG
          You can do that (unless I misunderstand what you wish)
          You need to create your scenes in SketchUp (with those layers on/off) and can load these scenes in LO (with the respective layers on/off).
          • porch_unpluggedP
            porch_unplugged
            how? at the minute, i have to draw a new dimension, select it, go to the dimension dialogue box, shape box & text box to change to what i want.
            yeah, i'm just looking for something a little easier. like if i forget to turn off a layer in sketchup for a scene, so that i don't have to go back into the sketchup model, change the scene, save and reload again in LO. just a time saver. or maybe i should just engage brain 😄
            cheers for responding so fast.
            • GaieusG
              Yes, but you do that once at the beginning. Then sample that style and apply it on the second dimensioning you add and from then on, it will "stick" throughout the session. (True it could be more intuitive).
              True again - some additional feature could provide more flexibility.
              • bmikeB
                bmike
                you can also set up some templates. i have a few single page templates with dimensions, text, notes, etc. setup off to the side. i use these to get started.
                yes, the sampling thing is a bit of a pain, and unintuitive, especially if you make up 'groups' of objects - like detail bubbles, leader lines, and text. the detail bubble may have a transparent fill, the text box the same, etc... but if you sample these things together as a group they can get wonky...
                • porch_unpluggedP
                  porch_unplugged
                  Cheers. I'm only using the trial version at the minute to see if i can make the jump to sketchup for planning/construction drawings etc. so i haven't spent the time setting up templates & scrapbooks. i guess efficiency (& resolutions to annoyances) will come with that.
                    ArCAD-UK
                    The Scrapbook is a great place for storing your styles and objects which you can either sample or drag & drop. I didn't realise how valuable they can be to the workflow until I started using them.
                    • utilerU
                      utiler
                      True Trevor. It would be nice if those scrapbook elements would retain layer info though....
                      Just Curious...
                      • pbacotP
                        I have an application that uses sampling--and you can set it to apply on individual objects inside groups or the whole group. It only samples styles from the object you click not the group.
                          Lemoyne Architect
                          The ability to import/insert vector images (dwg, ai, etc). Unless I'm missing something, there is no easy way to do this other than draw your own in Layout or modify the existing scrapbooks.
                            You can convert an inserted SketchUp view to vector images. First render the viewport as Vector and then explode it. Preto! Vector image in LayOut.
                            • B
                              Bertier
                              I'd like to be abble to link objects in LO with web content for presentation purpose
                              • B
                                Bertier
                                @billet323 said:
                                I would love to see a Warehouse for Scrapbooks. Its so time consuming to create scrapbooks for everything you do.
                                +1
                                  @bertier said:
                                  +1
                                  Anyone could start one.
                                    Lemoyne Architect
                                    Yes, but that means I have to import the DXF into SketchUp, lose any lineweight information, import the scene into Layout, render as vector, explode it, clean it up again...
                                    Not exactly a "presto" if you ask me.
                                      Lemoyne Architect
                                      @pbacot said:
                                      I suppose the point would be to be able to modify later in LO?
                                      Yes. I've used PDFs if I want to bring in something like a full architectural detail. But it would be nice to be able to bring in vectors directly for anything from custom section marks, symbols, and whatever else without having to draw them in LO or do the whole import through SU.
                                      • pbacotP
                                        I suppose the point would be to be able to modify later in LO? Otherwise is using pdf an alternative for now? The image is clear like a vector at any zoom level. It is a tall order, I gather, for dwg line weights etc. to be translated accurately.
                                        Alternatively some programs do a pretty good job of making vector files from vector pdf. [Edit: and what I mean is this might be a possible to develop for LO.]
                                          samyell77
                                          Just wanted to bump this up the list again - really hoping that LO gets a good going over soon
                                          •General speed increases, re-draws and re-links take an age with some files.
                                          •Better handling of files that are being accessed by machines on different operating system platforms so that links are not broken due to drive mapping issues on different platforms.
                                          •Stop render function so you can choose to stop a page from rendering if you spot an error instead of having to wait for every view to render (I know there's auto render but it would be great to be able to stop a page from updating and be able to update views individually or collectively)
                                          •Ability to use drawing labels with common and page only editable sections
                                          •Infinite zoom
                                          •Better handling of vector views - too slow at present
                                          •Automatic page numbering - and ability to add pages in order, ie add a page at the beginning of a 10 page doc and it will be page 01 rather than page 11. Number pages by order but be able to change names
                                          •Batch export for PDFs from LO documents - being able to export a page and have it take its name from the page name in LO rather than the overall LO document.
                                          •Multiple page sizes in same document (A4 and A1 for example)
                                          •Ability to reference model info from selected SU models in order to get component counts
                                          •Better handling of spread sheet data (cells, columns, tabs etc)
                                          •True text box sizes instead of oversized text boxes ie text box is a snug fit to the text rather that lots of spare space to left and right of text
                                          •Styles pallet for text - ability to name styles for dimensions, body text, notes, titles etc
                                          •Better ability to link scenes with LO so that sections and elevations retain their scale and dont throw dimensions out
                                          •Latest saved view causes lots of issues - you should have to save a scene in order to send a file to LO
                                          •Let the RUBY developers loose on Layout.... Please - this is the main strength in SU but something that is sadly lacking in LO
                                          The biggest one for me is speed and stability. LO is WAY too slow. I have a relatively new, well spec'd machine but LO is incredibly sluggish, laggy and unstable. Lots of ram, half decent gfx card and quad 2.26 CPU that deals perfectly happily with very large Photoshop, illustrator and indesign files but fall on its A55 when I make minor changes to a small LO file - like moving a text box?!!?
                                          LO is long overdue an overhaul....
                                          SU Pro 2016
                                          Dell Precision M4800
                                          PC Windows 10
                                          Intel Core i7-4900MQ @ 2.80ghz
                                          Nvidia Quadro K2100M
                                          16gb RAM
                                          • W
                                            Woodarc
                                            Supporting everything samyell77 has eloquently listed. Using Layout as I speak on an upgraded PC, waiting for it to catchup!
                                            • 3 / 5
