    Best way to iterate all nested entities
    29 Posts 9 Posters 6.5k Views 9 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Yea so you can also do this:
      verts = entities.grep(Sketchup::Edge).find_all {|edge| is_vertical?(edge) } entities.erase_entities(verts) unless verts.empty?
      P.S. @TT Yea I knew grep() is an iterator, but I usually avoid using a block with it, as it returns an array of block results which is a bit weird. (Especially when you expect a smaller subset than the whole.)
      I tend to just use it as a filter, and then call another method on the filtered results. IMHO the code is more readable. (.. and I don't confuse myself as much.)
      I'm not here much anymore.
        shannonnovus
        @dan rathbun said:
        Use the standard Ruby to_a() or grep() method to take a "snapshot" Ruby array copy of API collections.
        Then iterate THAT Ruby copy, viz:
        entities.grep(Sketchup::Edge).each {|e| e.erase! if is_vertical?(e) }
        Thanks Dan! The grep method worked great!
        @dan rathbun said:
        def is_vertical?(edge)
        >   vec = edge.start.position.vector_to(edge.end.position).normalize
        >   vec == [0,0,1] || vec == [0,0,-1]
        > end
        Your example for how to test for a vertical edge did not work for me, which could be entirely my fault. TIG's code from the other forum I mentioned did.
        edge.line[1].z.abs==1
        • tt_suT Offline
          tt_su
          To use the same tolerance as SketchUp does, use the methods built into the Ruby API:
          vector = edge.line[1] vector.samedirection?(Z_AXIS)
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/vector3d.php#samedirection?
          The components of a vector are floating point values so they should never be compared without a tolerance. For more information about floating point precision: http://floating-point-gui.de/
            slbaumgartner
            Excellent advice! Do you know whether Point3d#on_line? and #on_plane? also include the tolerance? The API docs don't say.
            • tt_suT Offline
              tt_su
              Yes it does. Do does Geom::Point3d, Geom::Vector3d and Length - which is why it's recommended you use those types when doing calculations, instead of using arrays and floats.
              Also note that Length + Length == Float (annoyingly). So you need to ensure you have a Length before outputting that to a string.
              • dkendigD Offline
                dkendig
                definition.instances.empty? won't give you an accurate indicator of the usefulness of a definition unfortunately. It can cut out some obvious ones to skip, but not all of the useless ones. If an instance is used in a definition, and that parent definition isn't instanced anywhere, the first definition will still say it has one instance. It's not wrong... but it's not helpful either. It would be nice to know if a definition is actually used in your model somewhere. Of course if you purge unused first, you should be fine. This can be especially frustrating when working with a model in which you are not allowed to purge unused definitions.
                Example:
                1. Make a cube
                2. Make the cube a component
                3. Make a copy of the component instance
                4. Make a new component out of the two instances
                5. Delete the resulting component instance
                6. Type this in the ruby console: Sketchup.active_model.definitions.each{|df| puts "definition #{df.name} instance count: #{df.instances.size}"};nil
                Devin Kendig
                Developer
                • tt_suT Offline
                  tt_su
                  Ah yes - very good point.
                    To check if a defn with instances actually has one or more if these inserted in the model, or also it is inside a 'container' that is itself inserted in the model, OR inside something else that is inserted in the model... etc...
                    Start count=0.
                    Look at each instance in turn and get its parent.
                    If its parent is the model then it is inserted (count+=1).
                    Elsif its parent is another component-defn you'll need to check if that definition has instances and iterate those and if their parent is the model (count+=1 and break) but if its parent is another component-defn repeat the nested testing of that definition having instances etc...
                    With an instance of Component#1 inside Component#2, and two instances of both in model.
                    ` instance_counter()
                    Component Name: Component#1
                    All Instances: 4
                    Inserted Instances: 2
                    Nested Instances: 2
                    Component Name: Component#2
                    All Instances: 1
                    Inserted Instances: 1
                    Nested Instances: 0
                    true`
                    With only 2 instances of Component#1
                    All Instances: 2
                    Inserted Instances: 0
                    Nested Instances: 2
                    All Instances: 1
                    Nested Instances: 0
                    true`
                    This is only to demonstrate the principal - clearly you'd want to hae a proper model/method that returned the counts for you...
                    require('sketchup.rb')
                    def instance_counter()
                    	def instances?(d)
                    		model=Sketchup.active_model
                    		cont=0
                    		d.instances.each{|i|
                    			parent=i.parent
                    			if parent==model
                    				cont+=1
                    			else
                    				cont+=instances?(parent)
                    		return cont
                    	puts
                    	model.definitions.each{|d|
                    		next if d.image? || d.group?
                    		puts "Component Name; \t#{d.name}"
                    		puts "All Instances;  \t#{d.instances.length}"
                    		count=0
                    		ncount=0
                    			parent=i.parent
                    			if parent==model
                    				count+=1
                    			else
                    				ncount+=instances?(parent)
                    		puts "Inserted Instances; \t#{count}"
                    		puts "Nested Instances;   \t#{ncount}"
                    		puts
                    	return true
                    Perhaps a method that takes the defn as its argument and returns the instances count in three arrayed integers [all, model, nested] ... [4, 2, 2] - like this:
                    def instance_count(d=nil) #d=defintion
                    	return nil if !d || !d.is_a?(Sketchup;;ComponentDefinition)
                    	return false if d.image? || d.group?
                    	def instances?(d)
                    		cont=0
                    			parent=i.parent
                    			if parent==model
                    				cont+=1
                    			else
                    		return cont
                    	count_array=[d.instances.length]
                    	count=0
                    	ncount=0
                    		parent=i.parent
                    		if parent==model
                    			count+=1
                    		else
                    	count_array << count
                    	count_array << ncount
                    	return count_array
                    • dkendigD Offline
                      dkendig
                      yes, generally this tends to do the trick, but we found that it was a tad faster to have your own lookup table that keeps track of definition relevance. The only downside, is that you are at the mercy of the observer system in that case, but the observers these days seem fairly stable, so that isn't currently an issue.
                      Devin Kendig
                      Developer
                      • 2 / 2
