    NPR LoftHaus 1 Rendering
    19 Posts 7 Posters 1.1k Views 7 Watching
      JohnLucente
      Forever amazed by your work.
      But I've noticed that you can tell that this is a computer rendered image.. I think you need a lil work with the brushes. move them in strokes that would resemble how a painter would actually brush the canvas. instead of just random strokes all either 0 or 90 degrees. Try to keep a stroke along a path of the same background color, and following background lines. I think a tablet would help tremendously with this style.
      but then again, i think the only reason I notice this is because I know your workflow now and can see it.... before I knew that, I wouldn't be able to tell ya know?
      anyways, sweet work as always man.
      cheers
      • allanxA Offline
        allanx
        Another very nice image, can you post your image without post pro?
        Thansk in advance
        Thanks Edgar,attached are images from sketchup and original composition...
        [Portfolio](https://www.coroflot.com/designers/work-stream?id)
        • allanxA Offline
          allanx
          cheers
          Thanks John, I will try your advice and see how will it look...
          allanx
          • allanxA Offline
            allanx
            Here are new materials for the created artworks...
            allanx
            • CarlohC Offline
              Carloh
              it's for a german company?
              • rodrigonotorR Offline
                rodrigonotor
                Thank you, is more clear now. Another question: People are 3D? from formfonts?
                Regards
                • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
                • allanxA Offline
                  allanx
                  Yes Carloh it's for a German company...
                  You are right Edgar the models are from Formfonts...
                  allanx
                  • CarlohC Offline
                    Carloh
                    stating by the location on your profile and that you have clients that far away, your name must be pretty big?! and the quality of your work of course also proves it 👍 i really am impressed! 😄
                    • pbacotP Offline
                      That last ones VERY cool Allan.
                      You use all 3d people?
                      Peter
                      • allanxA Offline
                        allanx
                        Thanks Carloh...
                        Yes Peter I used all 3D people for this work, from my experience and taste low poly 3D people from formfonts are excellent for this kind of work...by the way thank you for the nice comment on my tutorial... 😄
                        allanx
                          rodrigonotor
                          allanx
                          Hi Allanx, where is your tutorial?
                          • allanxA Offline
                            allanx
                            allanx
                            Hi Edgar, Its in the books section: http://books.sketchucation.com/
                            allanx
                            • Gus RG Offline
                              Gus R
                              I always enjoy your NPRs.
                              www.instagram.com/gusrobatto/
                              www.facebook.com/gusrobatto
                              • allanxA Offline
                                allanx
                                Thank you Gus...
                                allanx
                                  Quiet images 😎
                                  • allanxA Offline
                                    allanx
                                    Thank you Pilou...
                                    allanx
                                    • allanxA Offline
                                      allanx
                                      Another Re-make exterior shot from the project in Digital Watercolour style...
                                      Thanks,
                                      allanx
