    Thea renders - garden
    36 Posts 18 Posters 3.2k Views 18 Watching
    • boofredlayB Offline
      boofredlay
      Brilliant as usual. πŸ‘
        davidh
        Cmoreink,I converted thru 3d max to .obj and brought them that way into Thea.You can download a full working 30 days version of 3dmax which will allow you do the same.
          cmoreink
          Just like I thought πŸ˜‰ great images Dadvidh. Since you can't bring .max to SU and you bring them as .obj, do you loose any detail in those models?
          Would like to see how the last image NPR was composed.
          Thanks for your time.
          cheers
          my portfolio
            davidh
            The .obj models are brought into Thea and not into Sketchup.
            Before you export the models from 3d max you need to ensure that all the materials are standard max materials which means changing them from the vray materials which the models originally have ,otherwise all parts of the models will come through with the same texture.
            Once the models are in Thea I add translucency and bump maps and then save them out so they can be used as components/instantces.
            Once this is done I open the house Sketchup model in Thea and simply drag and drop the plants.
            I have attached 3 more variations of the NPR with different foregrounds and some colour tone revisions.
            • david_hD Offline
              david_h
              truly incredible. . .
              (So I am guessing that NPR in this situation doesnt refer to National Public Radio???) πŸ’š
              • jo-keJ Offline
                jo-ke
                I'm speechless. Absolutely perfect
                http://www.zz7.de
                  davidh
                  Heres a night time version using the technique I uploaded to the post processing forum a while back.I added a few fireflies to the right to add some bright colour.
                    cmoreink
                    I use vray ans SU, so I would have to bring the models straight to SU. I tried to import them to SU after exporting from 3ds max as .3ds since SU doesn't read .obj files, but no luck 😞.
                    Or maybe I'm just doing something wrong? I have also tried bringing them as .dwg or .dxf and it's no go either 😞
                    Does any one have an idea on how to do that?
                    thanks in advance
                    cheers
                    my portfolio
                    • jo-keJ Offline
                      jo-ke
                      Hmm. SU does import 3ds and obj! where is the problem?
                      http://www.zz7.de
                        davidh
                        I think the problem lies with the ".3ds format".It has a finite polygon count and if you export ,say for instance,from 3d max,particularly these plants,it can't handle it.
                        .OBJ has always worked for me.
                        Thats why I import into Thea.
                        I cant say enough about this program.I have previously used artlantis,vray and maxwell but for pure ease of use Thea is my default.It has cost me a lot of money over the years,and although I still use vray in sketchup for smaller models,Thea does everything I need to do.
                          cmoreink
                          It does imports .obj, but it's not a standard, you have to get a plugin.
                          I just installed a .obj plugin and imported, SU has been calculating now for over 10 minutes... still waiting, we'll see, keep your fingers cross. I just might have to look into thea.
                          cheers
                          my portfolio
                          • jo-keJ Offline
                            jo-ke
                            Ahh I see. Unfortunately highpoly is always a problem in su
                            http://www.zz7.de
                            • soloS Offline
                              Maybe not....seen this? http://www.thearender.com/forum/viewtopic.php?f=102&t=10982&start=0
                              • RichardR Offline
                                Richard
                                Davidh - mate trust that I mean this affectionately - YOU'RE A FREAK! The stuff you knock out blows me away!
                                [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                • KrisidiousK Offline
                                  Krisidious
                                  Wow... fantastic views. very realistic. My favorite is the last one. Wall worthy.
                                  By: Kristoff Rand
                                    cmoreink
                                    At first got a message to register, so I did. After I registered, clicked on the link again and it tells me that I'm not authorized πŸ˜•
                                    my portfolio
                                      davidh
                                      Thanks again for the compliments,especially the Freak one,Rich!
                                      Ive attached one more of the same house,rendered out again in Thea,and Photoshoped planting.
                                      This time I was going for a more ominous feeling,as the sun breaks through the clouds just before a heavy downfall.
                                      The barren trees at the back are used to try and help make for a more unsettling feeling,where a heavy dense growth of trees would only soften the effect.
                                        marne
                                        Great work, thanks for sharing!!!
                                          pibuz
                                          cheers
                                          Ehi Cmoreink: maybe you're using TIG's importer which is perfect but it's not written in C++ (faster).
                                          I usually use the fluidimporter plugin, which is totally free (or at least it was some time ago). Go and download it here: http://www.fluidray.com/downloads
                                          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                            cmoreink
                                            I use SU7, does it work with it? I use this .obj plugin http://www.scriptspot.com/sketchup/scripts/obj-importer
                                            Forget it, just installed your plugin and it does nothing, I mean there is nothing, it looks like SU8 plugin.
                                            my portfolio
                                            • 2 / 2
