    Draw calls - ????
    8 Posts 5 Posters 1.3k Views 5 Watching
    • I Offline
      iichiversii
      Ok I'm working on a project at the moment for mobile devices and the main term I'm finding hard to understand is draw calls, I understand that I need to keep texture size down low and can have only 30 draw calls in anyone scene, but I'm not entirely sure what exactly the meaning of draw calls are, does it only apply to textures and their size or does it also apply to polycount or the two combined, this is a quest to finer understand the term draw calls and if you could be so kind to help. Tips and tricks to reduce and keep draw calls low, are their plugins that help with draw calls etc etc...
      Thank you for advice given before hand πŸ‘
      Bring on the Rain...
        Draw calls?
        Think we need more info here... πŸ˜•
        • N Offline
          numbthumb
          Is this about Unity? There are some tips here:
          http://forum.unity3d.com/threads/27416-What-are-Draw-calls http://answers.unity3d.com/questions/14578/whats-the-best-way-to-reduce-draw-calls.html
          Comfortably numb...
          • I Offline
            iichiversii
            Yes it involves unity, for mobile devices draw calls need to be less than for exampla a pc, just winding does anyone have tips for managing draw calls using SU in unity?
              I have no idea what the definition of a draw call is...
              Surely that is something that is entirely based on the inner workings of Unity..?
                chrisglasier
                There is always Google of course. I wanted to know as well.
                • I Offline
                  iichiversii
                  Lol, no draw calls are the textures used with a model, iv being told a 1024x1024 size texture which is also known as 1 draw call, but a 520x520 texture is also known as 1 draw call but the amount of draw calls used in 1 frame or scene on for example an iPhone can't exceed 30 draw calls when using 1024x1024 textures, draw calls is a term I'm new to also, I was informed that when modelling in SU for a unity project with mobile devices draw call management is very important, if care isn't taken it slows down the performance, but does draw calls also take into account of polygon count or does it just apply to textures? I taught I'd ask if anyone has experience with draw call management, believe me I was just as baffled last nite when it was braught to my attention πŸ˜†
                    genma saotome
                    A draw call is a function used by a program to instruct the GPU to draw something. In games this is done once per frame, normally lots and lots of draw calls per frame (sort-of roughly analogous to your monitors refresh rate). In general you have one draw call per texture file used per object, but it may be more than that if you specify particular material types, ahh, check that, let's call it "qualities" so we SU folks are clear it's something different from SU materials, to influence the appearance of the texture. Such "qualities" might be gloss, brightness, various types of finish, like metal, rubber, wood, etc., and then whether there is an alpha channel present of not (transparency)
                    So given one model, 4 texture files, 2 of which have an area of transparency, 3 of which have areas where those "qualities" apply, the draw calls would be 4 for the four texture file as applied to a basic appearance, 2 for the transparencies, 3 for the "qualities, for a total of 9 drawcalls. For a game, that's 9 per frame for the one model. In a complex game there might be a couple of hundred models in view so that may add up to several hundred or even a couple of thousand draw calls, depending on complexity.
                    Because there is hardware involved each draw call is a CPU interrupt -- hello, this is long distance from America for Mr. Floyd... is Mr. Floyd there?.
                    In addition to letting the GPU know it is supposed to do something, a game will also provide the mesh for each object that is to be drawn, which is all of the xyz data that forms the vertexes of the model as well as the UV mesh which tells the GPU how to align the artwork. For each model for each frame.
                    In my experience it starts to get hard to keep frame rate equal to or above the monitor refresh rate when the draw call count exceeded 500 per frame.
                    On the front side of the glass sits the game player, who, quite naturally, does not want to see any slow-downs/speed ups. The net effect is to place a burden on model builders and artists to make their stuff so it requires the fewest draw calls possible. SU is not particularly good at this but at least has the benefit that things can be done very quickly and so it can have a proper place for both prototyping ideas and doing fairly basic game models.
