    [Done] Sphere with weird displacements?
    13 Posts 8 Posters 1.2k Views 8 Watching
    • GaieusG
      @rich o brien said:
      You simply need more geometry.
      Yes, the initial shape looks rather low poly fora really smooth render (especially for a close-up)
      Also most sketchup render apps require you to group/component geometry to apply a smoothing in the render.
      πŸ‘ πŸ‘ πŸ‘ This is also very important for many rendering apps.
      • B
        brknbrkn
        Thanks for the replies, here is a screen of the geometry. It is grouped btw but after smoothing nothing changes.
        [xxl-img:139mev01]http://www.efpp.nl/mush3.jpg[/xxl-img:139mev01]
        How would one create more geometry?
        • cottyC
          cotty
          It is often possible to define the subdivision (=smoothing) while exporting for the renderer...
          my SketchUp gallery
          • gillesG
            gilles
            when you select arc tool, circle tool or polygone tool you can type the amount of segment then Enter.
            if your arc.. is already drawn and not connected to other geometry you can change the amount of segment in entity window.
            if you draw an arc... type 24s ( for example) + Enter before doing another action.
            note: you must have an inner face in your shape
            • B
              brknbrkn
              Thanks Gilles, really helpfull that.
                ArCAD-UK
                I've just mocked up a half sphere and scaled it to be similar to your object with the same number of faces and it looks totally smooth. Couple of things to check...
                1 Go to window>Soften Edges and make sure "smooth normals" is checked and the "Angle between normals" is at a suitable figure of typically between 20 - 30 degrees.
                1. Look at the object in "Monochrome" mode and check all your faces are the correct orientation. If not they could be affecting the rendering.
                The only other aspect would be your construction method. Could something have distorted the geometery?
                • B
                  brknbrkn
                  I fixed it by using more segments. Thanks for the comments and help!
                  • N
                    notareal
                    This is a known problem; "terminator* artifact". It's Really Not a Rendering Bug, You See…
                    The terminator problem results from improper selfshadowing due to planar-polygon approximation of smooth
                    surfaces. This problem extends to mirror reflection, refraction, and Gouraud shading,
                    Fortunately some render engines can handle these models πŸ˜‰
                    Issue with commonly used fix; polygon count increases from left to right.
                    http://www.thearender.com/forum/download/file.php?id=5513
                    Treatment by Thea Render, no need to increase polygon count.
                    http://www.thearender.com/forum/download/file.php?id=5512
                    http://www.thearender.com/forum/viewtopic.php?f=17&t=4331
                    *A terminator is an area on a surface separating lit and selfshadowed
                    areas.
                    • GaieusG
                      This is indeed a great feature of Thea πŸ‘ I remember when it was introduced and can help a lot with low poly models - howeve note that th perimeter f the shape can still give a low poly onject away so there should still be a good balance between poly count and applying such advanced technology.
                      • N
                        notareal
                        True, low polygon model is "faceted" with the silhouette. Like in examples... there is nothing that can be done for it with selfshadowing. Only subdivision will help for that.
