    Forcing Sketchup to use IE8 and other Web Dialog problems
    24 Posts 5 Posters 2.1k Views 5 Watching
      Anton_S
      Same here, I also want to use latest Internet Explorer style; Buttons to be highlighted and rounded at corners like in IE8, checkboxes to be similiar to IE8, and everything else.
      I noticed that thomthoms Cleanup3 tool has a webdialog with a similiar context to IE8. How do I make all my HTML style to be similar to IE8? Like this?
      <!DOCTYPE html>
      <html>
      <head>
      <meta http-equiv="X-UA-Compatible" content="IE=8" />
      <!-- Some code -->
      </head>
      <body>
      <!-- Some code -->
      </body>
      </html>
      ... I checked it, via webdialog and it was the same as original old style.
        Isn't CSS round corners an IE9 feature?
          You mean the default style in IE8?
            Anton_S
            Well, I have IE9 then.
            Yes, but now I prefere IE9's default style.
              I don't know about the default styling in embedded web controls. I thought we where talking about CSS styling.
              The default styling I think might be affected by what common control manifest the host application uses...
              Can we perhaps see screenshots of desired result in a non-webcontrol Just to make sure we're talking about the same matters.
                Anton_S
                Here's an HTML Code opened via SketchUp Webdialog
                HTML code opened via SU8 Webdialog
                ...horrible 😞
                Now Here's an HTML code opened via IE9
                Same HTML opened via IE9
                ...just looks beatiful. πŸ˜„
                Here's the whole HTML code:
                <!DOCTYPE html>
                <html>
                <head>
                <meta http-equiv="X-UA-Compatible" content="IE=9" >
                <style type="text/css">
                  body {background-color;rgb(0,0,0)}
                  h1 {font-family;Tahoma; font-size;20px; text-align;center; color;rgb(0,140,255)}
                  h2 {font-family;Lucida Calligraphy; font-size;14px; text-align;right; color;rgb(255,255,255)}
                  p {font-family;Arial; font-size;12px; text-align;center; color;rgb(255,0,0)}
                </style>
                <script type="text/javascript">
                  function update_checked(){
                    var cb1 = document.getElementById("cb1").checked
                    var cb2 = document.getElementById("cb2").checked
                    var cb3 = document.getElementById("cb3").checked
                    var cb4 = document.getElementById("cb4").checked
                    var cb5 = document.getElementById("cb5").checked
                    var cb6 = document.getElementById("cb6").checked
                    var cb7 = document.getElementById("cb7").checked
                    window.location = ("skp;update_checked@"+[cb1,cb2,cb3,cb4,cb5,cb6,cb7])
                  function test_set_multiple(){
                    window.location = "skp;test_set_multiple@"
                  function set_menubar(){
                    window.location = "skp;set_menubar@"
                </script>
                </head>
                <body>
                <h1>Chain Multiple Commands</h1>
                <p><b>Check the following that you want to include in the "Set Multiple" operation.</b></p>
                <form>
                  <h2><b>SU Full Screen <input type="checkbox" id="cb1" onclick="update_checked()"/><br />
                  Viewport Client Edge <input type="checkbox" id="cb2" onclick="update_checked()"/><br />
                  Toolbar Stripts <input type="checkbox" id="cb3" onclick="update_checked()"/><br />
                  Statusbar <input type="checkbox" id="cb4" onclick="update_checked()"/><br />
                  Scenesbar <input type="checkbox" id="cb5" onclick="update_checked()"/><br />
                  Thread Toolbars <input type="checkbox" id="cb6" onclick="update_checked()"/><br />
                  Thread Dialogs <input type="checkbox" id="cb7" onclick="update_checked()"/><br /></b></h2>
                </form>
                <center>
                <button onclick="test_set_multiple()">Test Set Multiple</button><br /><br />
                <p><b>Note; Without a menubar there would not be a way to implement tools through shortcuts.</b></p>
                <button onclick="set_menubar()" >Set/Remove Menubar</button></center>
                </body>
                </html>
                  Right - I'm not sure what triggers that. Markup or the host application.
                  On a sidenote, maybe I suggest some comments on your dialog. Tone down the contract 255,0,0 red on completely black 0,0,0 background is very hard on the eyes. If you pick a slightly more subtle tone so the contrast ratio is less I'll be softer on your eye.
                  It's also best to stick with one font - and I recommend a sans-serif font (which is the de-facto standard in all applications). Script and fantasy styled fonts are not very legible.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    USE THIS META TAG:
                    <!DOCTYPE html>
                    <html>
                      <head>
                         <meta http-equiv="MSThemeCompatible" content="Yes">
                      <!-- Some code -->
                      </head>
                      <body>
                        <!-- Some code -->
                      </body>
                    </html>
                    I'm not here much anymore.
                      Anton_S
                      Yup, that works!
                      Thanks πŸ˜„
                        Anton_S
                        Thanks, helpful sidenote πŸ˜‰
                          Aerilius
                          I especially like this, it makes the dialog look less like a webpage and more like an application dialog.
                          The operating system's default fonts and colors can be achieved with CSS2.1 system styles (is supposed to be enhanced/replaced by CSS3 appearance, but only Firefox implements that properly). In WebDialogs, I set the background color manually because not all browsers/OSs do it right:
                          dlg.execute_script('document.getElementsByTagName("body")[0].style.background="'+dlg.get_default_dialog_color+'"')
                            Dan Rathbun
                            CSS3 Appearance has been cancelled in the latest revision. (And have not gone back to the 2.x docs, and removed those dire warnings.)
                              Dan Rathbun
                              I usually do it on the Ruby-side, before I call show(), ie:
                              dlg.set_background_color( dlg.get_default_dialog_color )
                                Dan Rathbun
                                @Anton: Users will hate your right-justified switches.
                                In a left-to-right language, the checkboxes are on the left, and each label is left-justified.
                                Try this to make it look more like a dialog:
                                <form>
                                  <fieldset hidefocus="true" tabIndex="-1">
                                    <legend>Chain Multiple Commands</legend>
                                    <label name="L1" id="L1" class="label_cbox">
                                    <input type="checkbox" name="CB1" id="CB1"
                                     class="form_cbox" checked="false"/> SU Full Screen</label>
                                    <!-- ... etc. ... -->
                                  </fieldset>
                                </form>
                                  Aerilius
                                  When I saw that method in the docs, I liked it also more until I found that it didn't work on Windows 7 (returned white).
                                  Interestingly, on Windows 7, the CSS color " %(#000080)[window]" is also white, but SketchUp's dlg.get_default_dialog_color works. I think driven reported similar problems with OS X (we then used a hard-coded gray for the OS X dialog).
                                  I wished this all was less complicated.
                                    Dan Rathbun
                                    Well.. it returns white on Win7 because that IS the system dialog background color "out of the box".
                                    (One reason I hate Windows 6+ is they try to make dialogs look like webpages!)
                                    Anyway.. a user can set their own theme, or download a premade theme from the Web, in which the dialog background may not be white at all.
                                    The other day, on XP, as a test I changed my system dialog color to Purple, just to test that method, and it worked, it returned the purple color that I had set. And SketchUp also used that color for background of it's dialogs and toolbars, etc.
