    Forcing Sketchup to use IE8 and other Web Dialog problems
    24 Posts 5 Posters 2.3k Views 5 Watching
      alexmojaki
      I use a Mac, and my Web Dialogs worked great there, but when I tested it on Windows they don't. Firstly, IE7 renders horribly. I installed IE8 and that looks better but I can see Sketchup is still using 7. Can I force it to use 8?
      Secondly, no scrollbars show. The required property in webdialog.new is true, and scrollbars are definitely needed. The content is clearly bigger than the screen.
      3: dialog.get_element_value isn't working. I know the required element ID exists and has a value because I've used javascript to test that it's there. But all I get is an empty string. This worked fine on Mac, it's as though IE is blocking the data from being sent.
      • Dan RathbunD
        Dan Rathbun
        1) I have noticed this also. document.documentMode still returns 7, even though you use:
        <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Strict//EN" "http://www.w3.org/TR/html4/strict.dtd">
        and:
        <meta http-equiv="X-UA-Compatible" content="EmulateIE8">
        I was thinking this morning, what would cause this?
        I wonder if it is because SketchUp is still using MSVC Runtime v8.x (2005). I believe the WebBrowser Control may be limited by the runtime version. (But this is only speculation on my part.)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          2) Scrollbars
          It is a bug, that on PC, the WebDialog's **scrollable** argument does not work.
          Depending on whether you are in Standards compliant mode or not, for PC, you need to use the scroll="yes" or ("no"|"auto") with the <HTML> or <BODY> elements (respectively.)
          Also the CSS overflow attribute may have some bearing on this issue.
          • Dan RathbunD
            Dan Rathbun
            3) Now that you mention it, I may have noticed some quirky behavior with that method.
            Because I have caught myself doing this instead:
            @dialog.execute_script %q[%(#800080)[window.location='skp:ValueToRuby@'+document.getElementById("MyID").value;] ]
            .. where ValueToRuby is some callback name you define with add_action_callback.
              alexmojaki
              1. Thanks, the scroll attribute worked. But what is Standards compliant mode? This is for a plugin that I want to distribute, so will this fix only work for some users?
              I don't understand. What do you mean by this sentence? I can't even see if you're suggesting a solution or just pointing out that you have the same problem.
              • Dan RathbunD
                Dan Rathbun
                @alexmojaki said:
                I don't understand.
                OK, then let me re-phrase.
                Here is a workaround:
                @value = nil
                @dialog.add_action_callback("ValueToRuby") {|dlg,value| @value = value }
                # Now use the callback;
                @dialog.execute_script %q[window.location='skp;ValueToRuby@'+document.getElementById("MyID").value;]
                # Now use the value;
                puts(@value)
                • Dan RathbunD
                  Dan Rathbun
                  [<!DOCTYPE>](http://msdn.microsoft.com/en-us/library/ms535242(v)
                  [Document Compatibility](http://msdn.microsoft.com/en-us/library/hh781499(v)
                  Quirks Mode
                    A valid HTML document with a strict doctype and meta tag to make IE use the latest render engine should work.
                    If it doesn't work then please validate your HTML, then post a code example.
                      Anton_S
                      Same here, I also want to use latest Internet Explorer style; Buttons to be highlighted and rounded at corners like in IE8, checkboxes to be similiar to IE8, and everything else.
                      I noticed that thomthoms Cleanup3 tool has a webdialog with a similiar context to IE8. How do I make all my HTML style to be similar to IE8? Like this?
                      <!DOCTYPE html>
                      <html>
                      <head>
                      <meta http-equiv="X-UA-Compatible" content="IE=8" />
                      <!-- Some code -->
                      </head>
                      <body>
                      <!-- Some code -->
                      </body>
                      </html>
                      ... I checked it, via webdialog and it was the same as original old style.
                        Isn't CSS round corners an IE9 feature?
                          You mean the default style in IE8?
                            Anton_S
                            Well, I have IE9 then.
                            Yes, but now I prefere IE9's default style.
                              I don't know about the default styling in embedded web controls. I thought we where talking about CSS styling.
                              The default styling I think might be affected by what common control manifest the host application uses...
                              Can we perhaps see screenshots of desired result in a non-webcontrol Just to make sure we're talking about the same matters.
                                Anton_S
                                Here's an HTML Code opened via SketchUp Webdialog
                                HTML code opened via SU8 Webdialog
                                ...horrible 😞
                                Now Here's an HTML code opened via IE9
                                Same HTML opened via IE9
                                ...just looks beatiful. 😄
                                Here's the whole HTML code:
                                <!DOCTYPE html>
                                <html>
                                <head>
                                <meta http-equiv="X-UA-Compatible" content="IE=9" >
                                <style type="text/css">
                                  body {background-color;rgb(0,0,0)}
                                  h1 {font-family;Tahoma; font-size;20px; text-align;center; color;rgb(0,140,255)}
                                  h2 {font-family;Lucida Calligraphy; font-size;14px; text-align;right; color;rgb(255,255,255)}
                                  p {font-family;Arial; font-size;12px; text-align;center; color;rgb(255,0,0)}
                                </style>
                                <script type="text/javascript">
                                  function update_checked(){
                                    var cb1 = document.getElementById("cb1").checked
                                    var cb2 = document.getElementById("cb2").checked
                                    var cb3 = document.getElementById("cb3").checked
                                    var cb4 = document.getElementById("cb4").checked
                                    var cb5 = document.getElementById("cb5").checked
                                    var cb6 = document.getElementById("cb6").checked
                                    var cb7 = document.getElementById("cb7").checked
                                    window.location = ("skp;update_checked@"+[cb1,cb2,cb3,cb4,cb5,cb6,cb7])
                                  function test_set_multiple(){
                                    window.location = "skp;test_set_multiple@"
                                  function set_menubar(){
                                    window.location = "skp;set_menubar@"
                                </script>
                                </head>
                                <body>
                                <h1>Chain Multiple Commands</h1>
                                <p><b>Check the following that you want to include in the "Set Multiple" operation.</b></p>
                                <form>
                                  <h2><b>SU Full Screen <input type="checkbox" id="cb1" onclick="update_checked()"/><br />
                                  Viewport Client Edge <input type="checkbox" id="cb2" onclick="update_checked()"/><br />
                                  Toolbar Stripts <input type="checkbox" id="cb3" onclick="update_checked()"/><br />
                                  Statusbar <input type="checkbox" id="cb4" onclick="update_checked()"/><br />
                                  Scenesbar <input type="checkbox" id="cb5" onclick="update_checked()"/><br />
                                  Thread Toolbars <input type="checkbox" id="cb6" onclick="update_checked()"/><br />
                                  Thread Dialogs <input type="checkbox" id="cb7" onclick="update_checked()"/><br /></b></h2>
                                </form>
                                <center>
                                <button onclick="test_set_multiple()">Test Set Multiple</button><br /><br />
                                <p><b>Note; Without a menubar there would not be a way to implement tools through shortcuts.</b></p>
                                <button onclick="set_menubar()" >Set/Remove Menubar</button></center>
                                </body>
                                </html>
                                  Right - I'm not sure what triggers that. Markup or the host application.
                                  On a sidenote, maybe I suggest some comments on your dialog. Tone down the contract 255,0,0 red on completely black 0,0,0 background is very hard on the eyes. If you pick a slightly more subtle tone so the contrast ratio is less I'll be softer on your eye.
                                  It's also best to stick with one font - and I recommend a sans-serif font (which is the de-facto standard in all applications). Script and fantasy styled fonts are not very legible.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    USE THIS META TAG:
                                    <!DOCTYPE html>
                                    <html>
                                      <head>
                                         <meta http-equiv="MSThemeCompatible" content="Yes">
                                      <!-- Some code -->
                                      </head>
                                      <body>
                                        <!-- Some code -->
                                      </body>
                                    </html>
                                      Anton_S
                                      Yup, that works!
                                      Thanks 😄
                                        Anton_S
                                        Thanks, helpful sidenote 😉
                                          Aerilius
                                          I especially like this, it makes the dialog look less like a webpage and more like an application dialog.
                                          The operating system's default fonts and colors can be achieved with CSS2.1 system styles (is supposed to be enhanced/replaced by CSS3 appearance, but only Firefox implements that properly). In WebDialogs, I set the background color manually because not all browsers/OSs do it right:
                                          dlg.execute_script('document.getElementsByTagName("body")[0].style.background="'+dlg.get_default_dialog_color+'"')
                                          • Dan RathbunD
                                            Dan Rathbun
                                            CSS3 Appearance has been cancelled in the latest revision. (And have not gone back to the 2.x docs, and removed those dire warnings.)
