    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 30.3k Views 16 Watching
      I'd be very interested in hearing how you get on with it and any description/mini-tutorial if you would care to do one. I'm very fresh to C so I'd love to learn this.
      • I Offline
        ishboo
        I talked to my colleague and we're gonna try to hack on it this Saturday at our weekly hackathon. Will update if we get around to it. πŸ˜„
        SketchUp plugin marketplace: http://extendsketchup.com/
        • Dan RathbunD Offline
          Dan Rathbun
          As as I mentioned before.. there are already Ruby bindings.
          Curb looks like the most recent, it was last updated June 29, 2012:
          http://rubygems.org/gems/curb
          I'm not here much anymore.
            Dan Rathbun
            Stay away from Cygwin.
            If you cannot use MSVS.. at least use MingGW.
            Here's the link to download the source (which comes with precompiled binaries for curl.exe)
            http://curl.haxx.se/gknw.net/7.26.0/dist-w32/curl-7.26.0-devel-mingw32.zip
            OR.. if you just simply want the precompiled binaries (without source):
            http://curl.haxx.se/gknw.net/7.26.0/dist-w32/curl-7.26.0-rtmp-ssh2-ssl-sspi-zlib-idn-static-bin-w32.zip
            Has both pre-compiled curl.exe and libcurl.dll, as well as a few more dll files.
            And how to build on various platforms:
            http://curl.haxx.se/docs/install.html
            πŸ’­
            • I Offline
              ishboo
              Thanks for the links Dan πŸ‘
              I would assume this would mean the end user would need to install the gem for it to work?
                πŸ‘ πŸ‘
                  Why is this?
                    Dan Rathbun
                    Well, no... gems do not work with Sketchup embedded Ruby.
                    Actually want is probably needed is to look at the handfull of gems and write a Sketchup friendly "clone".
                      Dan Rathbun
                      Why is this?
                      My advice. (From what I have read.)
                      If you want expert advice, ask Luis Lavena over at the Ruby Installer project forum.
                        Dan Rathbun
                        On this subject:
                        Redirecting to Google Groups
                        (groups.google.com)
                          designingcrime
                          Hey guys, so I finally got a Ruby C extension to compile on both os x and windows and link curllib. I got a lot of help from Luis at the RubyInstaller group and ended up using RubyInstaller and DevKit to link curl and build using the gcc compiler included with devkit.
                          Here is the extension. Its a modified version of Dana's sketchup downloader, but also included uploading, basic http authentication and ssl certificate checking(all through curl). I provided instructions on how to build on both os x and windows.
                          https://github.com/sunglass/SunglassPlugins/tree/master/SG-SketchupHook/src/Connection%20Manager
                          Thanks for all your help guys.
                          Dana - Lets get your Sketchup downloader plugin working.
                             :heart_eyes:
                            • I Offline
                              ishboo
                              That's awesome news! Congrats!
                              I'll have a look at it soon and try to finish up the tool πŸ˜„
                                Anton_S
                                Lets, say I compile a HelloWorldEx on windows7, will it be the same as compiling it on XP?
                                  Dan Rathbun
                                  I would think it would depend upon which MSVC runtime you use.
                                  Which ever you use, the user(s) will need to have that version installed on their machine(s), regardless of whether they are running Win5.1 (XP,) Win6.0 (Vista) or Win6.1 (Win7.)
                                  SketchUp itself lists MSVC ver 8.x (2005) as a dependent assembly in it's manifest.
                                  There ARE some programmers that have compiled extensions and linked to ver 10 (2010), but they must give the Microsoft download link to install that runtime version, and list it as a dependancy.
                                  Reference:
                                  http://en.wikipedia.org/wiki/Visual_C++
                                  πŸ’­
                                    Anton_S
                                    Hmm, I have win7 and windowns XP mode virtual pc, on the same comp.
                                    Under Win6.1(win7), I recompiled win32/api.so to my own namespace with a name changed to win32/msp_api.so. ( MSPhysics::Win32::API)
                                    It worked pretty well, until I've desided test it on WinXP mode virtual pc. WinXPmode had ruby-186-27, SU8, and some more raw programs, though it did not have MSVC.
                                    Then, I started SU 8 and got this error:
                                    msp_api.so without msft visual c++
                                    Before I installed msvc 2010, I desided to test the native win32/api.so and seeing it working wasn't expected; Apperently the native win32/api.so worked pretty well, without showing any errors, and without msvc.
                                    Being a little confused I desided to download msvc 2010 Redistributable Package (x86), to test whether my win32/msp_api.so would actually work on XPmode. After downloading, it worked now, but there was one question left: How did native win32/api.somanaged to work without msvc? ❓
                                      No - you don't have to link to the runtime.
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=41077&start=105#p411657
                                      After a simple change in a compiler flag I could use the .so without the runtime installed.
                                        Dan Rathbun
                                        Because the SketchUp Installer installs MSVC 8.x (2005) runtime if it is not installed. The MSVC runtime install, might seem transparent to the user installing SketchUp, if they do not pay close attention.
                                        Most XP machines will likely already have this older MSVC ".NET" runtime version installed if Automatic Windows Updates are turned ON.
                                          Dan Rathbun
                                          (Ruby-Talk GoogleGroup) Common Traps for C extensions
                                            tomasz
                                            I am trying to build the Basic sample under Xcode 4.4, but I am probably doing something wrong, because the resulting bundle fails to load into SU. I get "#<LoadError: myplugin.bundle Failed to load myplugin.bundle". I do not even get the "Failed to find init.. " error.
                                            When compiling with extconf.rb and make the plugin loads just fine.
                                            What project type should I start with to get the extension running? I have already tied /Framework/Bundle, Generic C++ Plug-in. How can I force the -flat_namespace in Xcode?
                                            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                            • 6 / 9
