    Deleting Layers - or....
    6 Posts 2 Posters 251 Views 2 Watching
      kybasche
      Hey folks.
      I've been messing around with the VolumeCalculator21 plugin, trying to figure out what controls the addition of the copied volume to a new layer. I'd like to have the plugin NOT create the new layer and copied volume (or, alternatively, delete them after they are created and used).
      Is there a way to delete a layer and its contents from within ruby?
      Can anyone tell me which lines of this plugin are "copying" the selected volume into the newly created layer within the plugin?
      I've attached the plugin for reference.
      Derek
      VolumeCalculator21.rb
      • TIGT Online
        To make it so that it always uses the 'default layer' as the default value in the dialog, change
        values = [@units,@layer,@hidden,@colour,@hide]
        to read
        values = [@units,**dlayer**,@hidden,@colour,@hide]
        OR before @layer is used to set a layer put '#' in front of each of these lines
        layerVolume=@layer if layerVolume layerVolume=model.layers.add(layerVolume) layerVolume.page_behavior=(LAYER_IS_HIDDEN_ON_NEW_PAGES | LAYER_HIDDEN_BY_DEFAULT) layerVolume.visible=true end#if
        and add
        layerVolume=nil
        To put the volume-text onto the default layer add a '#' in front of all lines of this code, so no layer is made used
        layerVolumeText=@layer+"-TEXT" if layerVolumeText layerVolumeText=model.layers.add(layerVolumeText) layerVolumeText.page_behavior=(LAYER_IS_HIDDEN_ON_NEW_PAGES | LAYER_HIDDEN_BY_DEFAULT) layerVolumeText.visible=true end#if txt.layer=layerVolumeText
        To remove the object you might think to use this just before the ' end#def Volume::process' line...
        vol.erase!
        BUT then that will erase the text too !!
        So to keep just the volume's text use
        ventities.erase_entities(ventities.to_a-[txt])
        To explode the text so it's no longer inside a group you can add
        vol.explode
        after erasing everything except the text [txt]...
        Remember that none of the tool's 'listing' code will now work as there are no 'volumes' to process...
          kybasche
          Brilliant! Still so many things to learn...
          Thanks πŸ˜„
          D
            kybasche
            I spoke too soon!!!!
            I think I followed your instructions well (though, I don't rule out user error) - but when I run the script and actually pay attention I noticed that the volume and text are NOT being deleted.
            In the ruby console I get an error that:
            Error: #<NameError: undefined local variable or method `vol' for Volume:Class>
            Have I put the vol.erase! line in the wrong place? I located it, as you said, just before the Process code ends.
            Any ideas?
            Thanks πŸ˜„
            D
              kybasche
              I moved the vol.erase! line to just after
              vol.set_attribute("Volume","Tag",true) ### v1.8
              in Volume::process
              and it seems to be working.
              Is there something between
              and the end of that defwhich makes volno longer available?
              D
              • TIGT Online
                Around line #302 is the text
                place you additional code on its own line, just before that - vol.erase! etc to remove the vol-group etc...
