    Sample Model for Rendering
    37 Posts 22 Posters 9.8k Views 22 Watching
    • Al HartA Offline
      Al Hart
      We are posting some models to the 3D Warehouse to use as sample models for rendering.
      Take a look at this one: Interior Conference Room Sample Model
      http://sketchup.google.com/3dwarehouse/download?mid=36a7ed45e50220ecfe5459ef51ea0c07&rtyp=lt&ctyp=other&ts=1342106187000
      Add some rendering parameters, render it with your favorite renderer and post the results here, or send them to me at al.hart@renderplus.com.
      It is OK to add materials, backgrounds, and other rendering settings - but do not add or change geometry - unless there is something stupid wrong with the original model.
      When you post it here or send it, let me know if it is OK to post your image on SketchUpRendering.com. I will place some good examples from various rendering packages on that site. Include any other useful information - name of rendering package, special effects used, etc. Let me know what credit I should put on your image: (Rendered by...)
      Al Hart
      IRender nXt from Render Plus
      • Al HartA Offline
        Al Hart
        I ran this through IRender nXt.
        Reflections were added to the ceiling, Index of Refraction to the glass table top and lights behind the light grids.
        100 passes - about 2 hours rendering time.
        http://wiki.renderplus.com/images/1/1d/Meeting_room_sample-100.jpg
        Al Hart
        • Bryan KB Offline
          This looks interesting. I'll post something this weekend.
          Some quesitons:
          My rendering program may not recognize the existing lights. Can I add them if needed as long as they are exactly where the originals are placed? If so, what are the general settings? Omni? Directional? Brightness? Is the exterior lighting a "sun" or more lighting?
          Thanks.
          • Al HartA Offline
            Al Hart
            Thanks for giving this a try. You can add lights, replace the lights, etc. depending on how your rendering program works.
            I didn't create this model - but I believe the lights are either a face set to emit light, or a "ceiling light" placed behind the grids of the ceiling. It is probably marked as directional pointing down, but if it is behind the grid, then onmi-directional would work as well. You should choose the brightness what works to get the proper balance of sun, sky and lights, or go for a night time scene, etc.
            In the rendering I created I the sky was on but not the sun. However, you are not trying to produce the same rendering, but rather to show a rendering you could get from the same model - for instance a rendering which would be good to show a client for whom you were designing this room. For instance you could make more, or different materials reflective, and have different reflection settings. The purpose of this thread and/or the SketchUpRendeirng.com site, where we will post these images, is to show SketchUp users the value of using add-on rendering packages to improve the quality and value of SketchUp models and images for internal or client presentations.
            Al Hart
              teknikarsitek
              here is my test .. using vray for sketchup ..
              hope u like it
              test render by ferry
              • O Offline
                Ollo81
                Here is my first attempt to render this scene with Thea. So far I'm not too happy with the door area and its lighting. CC are welcome.
                • jason_marantoJ Offline
                  jason_maranto
                  Here's a whack at it with Maxwell -- I tried to make the least amount of changes possible, but I did opt to use a free sample HDR for the background from http://www.hdri-locations.com/ for a more subdued tone. I used the Maxwell "Simulens" effects at the end for a bit of bloom and whatnot.
                  I'll probably take another whack at it with more custom materials and add some lights.
                  Best,
                  Jason.
                  • oganocaliO Offline
                    oganocali
                    Render at noon, no background. vray + gimp(for contrast+brightness adjustment). I only added a few reflective layers and studio lights.
                    • CarlohC Offline
                      Carloh
                      here my quick attempt using lumion free version. some of the materials are from the maxwell material library.
                      • Al HartA Offline
                        Al Hart
                        Is it OK to upload this to the SketchUpRendering site, and mention you as the contributor?
                        If you re-render it later, we can update the image on that site as well.
                        Al Hart
                        • CarlohC Offline
                          Carloh
                          Sure, that would be really nice! Just make sure you don't take any commercial advantage of this image as the lumion free version is for non-commercial use only. 😄
                          • jo-keJ Offline
                            jo-ke
                            twilightrender setting 02 low
                            used the materials in model, added some bump, lights and background
                            removed backfaces in chairs
                            little correction in PS
                            http://www.zz7.de
                              MrMikeEsq
                              Carloh, what was the render time?! 😉 😆
                              • CarlohC Offline
                                Carloh
                                something between 10 and 15 seconds 😄
                                • jo-keJ Offline
                                  jo-ke
                                  and another one
                                  twilight render preset 9
                                  27 passes for 1,5 hours
                                  http://www.zz7.de
                                    jason_maranto
                                    Here's another shot with Maxwell using some of my Arroway and RAL materials -- I also added more lights and re-arranged the existing ones slightly. I'm not sold on the floor I used, I may do another version at some point.
                                    Also I really think this model needs more details, like baseboard/trim and electrical sockets to be a bit more interesting/realistic.
                                    Best,
                                    Jason.
                                      JCA131
                                      I hope I'm not outside of the rules by creating all new materials instead of just editing the materials from the original model.
                                      Twilight Render and Photoshop
                                      • jo-keJ Offline
                                        jo-ke
                                        another one, just for fun. Added my wife and myself
                                        twilightrender preset 9 2,5h, 43 passes
                                        http://www.zz7.de
                                          macmac12
                                          here's my render, using vray for sketchup.hope you like it.
                                          http://img268.imageshack.us/img268/4323/mettingroom.jpg
                                          Uploaded with ImageShack.us
                                            mwm5053
                                            The wife and girl friend.
                                            I stayed at home to do the rendering. Kerkythea Photomap high+ AA 0.03. I'll let it bake tonight and see any better quality at least with the lights.
                                            2011 iMac
                                            SU 2015 Pro, 2017 Make
                                            V2 Twilight
                                            macOS Sierra 10.12.5
