    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 46.3k Views 16 Watching
      hm... there is an msvcrt-ruby18.dll in the SketchUp folder - can I make my Visual Studio C++ project rely on this instead? So when the C Extension loads under SketchUp Ruby the runtime is there - installed by SketchUp. ??
        And can you explain what your workaround actually do?
        isinf is already defined in PellesC libraries so there is no need to include that file again.
        But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
        Building hello_world.obj.
        Use <stdlib.h> instead of non-standard <malloc.h>
        C;\ruby\src\ruby-1.8.6-p111\missing.h(71); error #1050; Redefinition of macro 'isinf'.
        *** Error code; 1 ***
        Done.
          http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
          When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
          • tbdT Offline
            tbd
            http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version. also you can copy the msvcrt-ruby18.dll in your dev directory to be picked up when debugging outside Sketchup (which I hope you do, otherwise dev time is slooooow)
            http://plugins.ro
            • tbdT Offline
              tbd
              that's why you need to have #define HAVE_ISINF 1 in your code, so that Ruby will not double include
              compile with the same VC πŸ˜„ or dont link any CRT and use a replacement static lib (there are some minimal libs on the net)
              http://plugins.ro
                _MSC_VER == 1200 = MVC 6, right? Can you get hold of that version any more?
                Here you lost me. "linking"... another concept I need to learn.
                  That is still greek to me... The only thing I compiled before these Ruby C Extensions where Visual Basic 4 applications... πŸ˜’
                  • Dan RathbunD Offline
                    Dan Rathbun
                    As .. in statically linked, or dynamically linked.
                    (Hence the DLL and dylib, means Dynamically Linked Library.)
                    πŸ’­
                    I'm not here much anymore.
                    • tbdT Offline
                      tbd
                      if you want to have fun - http://www.benshoof.org/blog/minicrt/
                      http://plugins.ro
                        hmm... so I could take my C Extension made with VC++'s nmake and statically link the RT - avoiding having to bundle it or require the users to install any additional RT?
                        • tbdT Offline
                          tbd
                          yes. the dll were created to solve the duplicate code problem but they created another problem - the DLL hell.
                          but for SU extensions having a couple of kB duplicated for the CRT is ok. also it makes the installing easier.
                          http://plugins.ro
                            And from I gathered of the Wiki article, then the DLLs are statically linked they can link just the part of the library required. ??
                            Now I need to figure out how to statically link the CRT. Is it as simple as a compiler flag?
                              -MT instead of -MD seem to be the one...
                              http://stackoverflow.com/questions/8463073/nmake-vc-2010-compile-without-msvcr100-dll-depends
                              http://msdn.microsoft.com/en-us/library/2kzt1wy3%28v=vs.80%29.aspx
                                Changed compiler flag from -MD to -MT
                                  On a real world project, Vertex Tools:
                                  I can live with that. πŸ˜„ Now it "just works" on even the freshest of systems.
                                  • tbdT Offline
                                    tbd
                                    DLL = Dynamic Linked Library - so they cannot be statically linked (except embedding it in resource and dropping it on execute πŸ˜„ )
                                    statically linked libraries (eg. CRT.lib) should add only the used routines to the final executable.
                                    http://plugins.ro
                                      designingcrime
                                      I have been working on a plugin to upload and download files to a webserver through http requests. I found this project on the forums a while ago but It wasn't working.
                                      https://github.com/danawoodman/google-sketchup-file-downloader
                                      Now I have it working and the C Extension compiled fine in Os X.
                                      I have been trying to figure out how to compile it in Windows now so that the plugin can be cross-platform. I started reading this thread but its kind of confusing for me. After following the instructions in this project (which I think are a product of this thread)
                                      https://bitbucket.org/thomthom/sketchup-ruby-c-extension/
                                      I can compile the example code here with extconf.rb and nmake. However compiling dana's extension is a bit more complicated because it links to libcurl.
                                      there is a line in extconf.rb to check for curllib
                                      Make sure the cURL library is installed.
                                      have_library("curl")
                                      its not
                                      checking for main() in curl.lib... no
                                      creating Makefile
                                      So when using nmake I get this error
                                      fatal error C1083: Cannot open include file: 'curl/types.h': No such file or directory
                                      I downloaded libcurl(curl-7.26.0-devel-mingw64, im on windows 7 and not sure which is the best)
                                      So I can't figure out how to tell nmake to include the path, or where it looks for these files.
                                      Does anyone have experience making ruby c extensions on windows and know how to include 3rd party libraries?
                                      Any help would be appreciated.
                                        I tried to compile Dana's library as well, but since the GiHub project doesn't include the CURL files it failed. And none of the packages I found at the CURL sitecontained the linked files. I asked Dana for which package he used, but it doesn't seem he found it again.
                                        There's another thread around here that talks about Dana's repository.
                                        Need to find out what CURL files are required.
                                        • I Offline
                                          ishboo
                                          Hey y'all,
                                          I have not tried compiling on windows since I own a mac. On Mac libcurl is installed system wide so it is more straightforward setting it up.
                                          One thing that may work is trying to install libcurl using Cygwin and then trying to compile it in Cygwin as well.
                                          I have a coworker who runs windows, so I'll have him an I check it out next week and see what we can find out!
                                          SketchUp plugin marketplace: http://extendsketchup.com/
                                            Dan Rathbun
                                            This one?
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=38689&p=415237#p415237
                                            • 6 / 9
