    How to get entities from selection?
    11 Posts 4 Posters 1.0k Views 4 Watching
    • lbsswuL Offline
      lbsswu
      I have a selection object with several entities, I am confused about how could I get all the entities from the selection object?
        You mean into an array? The Selection object is an Enumerable so you can iterate it as normal. It also have a .to_a method so it can often be mixed with arrays.
        How do you want to "get" the entities? Iterate them?
        • lbsswuL Offline
          lbsswu
          I just want to inplement the following code:
          entities = selection.entities (this function is what I wanted, but not exist)
          group = entities.add_group
          group.add entities (this function is what I wanted, but not exist)
          bounds = group.bounds
          center = bounds.center
          Is there any way?
            Aerilius
            Yes:
            entities = selection.entities #
            # "The entities method is used to retrieve
            # a collection of entities in the group."
            group.entities.add entities
            Sketchup::Group, Sketchup::ComponentDefinition and Sketchup::Model are similar "containers" for entities (in fact components are models in a model; and a model can be inserted as component).
              If you want to group a selection then it's safe to do it as the group is made as the selection must be in the active_entities [cross-threading group/entities will splat!]
              group=model.active_entities.add_group(model.selection.to_a) center=group.bounds.center
              However, if you are doing it to find the center of a selection and then exploding the temporary group you could do it different ways, e.g. ...
              bb=Geom::BoundingBox.new model.selection.each{|e| bb.add(e.bounds) } center=bb.center
              You can of course filter objects for the added bounds, by including tests inside the {}, e.g. to include only groups insert an early
              next unless e.is_a?(Sketchup::Group)
              • lbsswuL Offline
                lbsswu
                @aerilius said:
                Yes:
                The first line has a "NoMethodError" error...
                  Try my suggestion[s] - far easier to understand and get results if you read the alternatives carefully....
                  I believe that Aerilius was thinking that your 'selection' was actually a 'group'.
                  Then the 'group'.entities would have worked...
                  • lbsswuL Offline
                    lbsswu
                    Thanks TIG! I have tried your suggestions. It works, but maybe there is a bug in my script, I did not get the correct coordinates.
                      Without at least a few clues we can't help you much further πŸ˜•
                      If you are trying to find the center of a selection of objects then my examples will return the bounds.center
                      You never explained properly what it is you are trying to do...
                      We answer your query only to find it's not the answer to the question you ought to have asked really πŸ˜’
                      Can you explain what you seek and we might help with a path to get there.
                      Sometimes you seem to have gone half way down the wrong road and then ask us how to get to you destination by carrying on, when really you need to go back to the start and set off in the correct direction as it'll be much easier/quicker...
                      • lbsswuL Offline
                        lbsswu
                        My task is get the parts' center of a 3D car model. I find the problem which posted in the website:
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=46520&p=416248#p416248
                          Sample test model?
