    Need Help!! How to model this kind of form/surface?
    Scheduled Pinned Locked Moved Organic Modelling
    33 Posts 7 Posters 20.6k Views 7 Watching
    • brookefoxB Offline
      brookefox
      I have not studied your link. I looked but the images were small and not very revealing. Consider this: the project was originally sculpted in stiff whipped cream and then photo digitized into a 3D model. From there it went into production, and in some cases, it went viral. Try to sculpt it yourself and proceed as they did.
      EDIT: No. I am wrong. It was modeled in pulled taffy, then chopped neatly.
      There is, however a wealth of filler available to augment the puffing up of the creamed taffy:
      The Museum’s massing becomes a diagram of these geological forces visible in the sedimentary creases abundant on the facade. Using parametric techniques we were able to visualise these layers and texturise the facade to implant an identity which echoes time through its weathering. Emulating these natural landform processes frees a language intrinsically linked with ‘Place’ while hinting of this ‘place’ as a time before human history. This Experiment with an abstracted ‘Growth’ of a building has taken the form of accentuating the landscape, creating distinct man made insertions to augment the existing topography and give the museum its identity.
      And therein may lie some important clues to guide us in the resolution of this conundrum.
      ~ Brooke
        sephy
        Hi brookefox:
        my idea is there might be two way to generate this form:
        the first way is more close to pbacot & leminilab's suggestion. draw some curves first, adjust their position and loft them. this method can generate a kind of simulated shape but will have less control and give you less opportunity to play around and generate another form.
        the second way is like what you said: to create a mass first, modify the mass by some commonds, like twisting,stretching? this way might have more control but don't know how to do it in detail.
          As you can make intersections any architectural volumes not convoluted can be made easily 😉
          Here only with the Projection By Didier Bur
          (a curve along a vector)
          Make normal crossing PushPull don't make the internal faces!
          Forget that 😄
          Make the normal PushPull but with CTRL 😉
          Select all / Intersection
          Kill not wanted
          And make Orient faces
          But for inclined surfaces the first Projection method stay valuable 😉
          • pbacotP Offline
            Pilou--
            Although I usually don't understand you, perhaps you can break down steps to get the pillowy form in the last picture. Si vous plait,
            Merci, Peter
            Sephy-- that's far out. Can't really say much about it. Some of these architects, similar to BF comments, build models out of paper or whatever and an assistance digitizes with a 3d digitizing device. Then they use Catia or some advanced program to take it from there. Pulled taffy is a good guess, or it could follow dynamics foam rubber sheets squashed, folded and pinned. 😄
              brookefox
              I hope he doesn't take that as some kind of crazzy personal challenge. 💚 His pictures usually do tell a good story.
              In retrospect it occurred to me that (as referenced in the marketing blurb), eroded sandstone and the like can look quite like pulled taffy, though it is not so bad for your teeth.
              ~ Brooke
              • pbacotP Offline
                I exaggerate. 😛
                  break down steps
                  I am not sure to understand this 😳
                  Something like this ?
                  • pbacotP Offline
                    Pilou,
                    I mean, the steps to get to the shape you showed. 😄 I get the projection for the curve but what did you use for the dome-like portion, Merci, le Bacot
                    • pbacotP Offline
                      🎉 So you have been to my favorite place?
                      http://upload.wikimedia.org/wikipedia/commons/thumb/6/6d/Canyonlands_Needles.jpg/600px-Canyonlands_Needles.jpg
                      • pbacotP Offline
                        Thank you, I think I got it! That plugin does interesting things! Peter
                          Ah Ok 😄
                          In the previous I have just drawn an arc circle (second curve = rail) for the "Dome" and make like this 😉
                          You need just 2 curves! (second is not obliged, it's just an "helper line" as you can click anywhere! 🤓
                          Just At the beginginning you must Select the first curve (after it's memorized! )
                          You can stop at any moment! And reselect the curve if you have missed one point 😉
                          But careful if you miss one first green point that's failed so stop sometimes for the stress! 💚
                          Else it's very powerful when you have rail (second curve) not convoluted!
                          It's just few clicks for big effects! 😎
                          And for something else it's very useful for closed sections on the fly!
                          A very funy plugins! 👍
                          Here the first and second curve(rail) are the same so at the end I will have a square "russian mountain" 😉
                          For the next "segment" firt click will be the previous "last click" green point!
                          Of course you have other plugs (Extrude edged by edges by Tig), or even the follow me (you must draw a surface more)that make the same in one click
                          but here you have total control if you want jump a raw and more possibility to click anywhere!
                          For reselect a curve don't hesitate to use the view top !
                            ...and big advantage you can extrude any segment in the same time even separated!
                            and very useful when you want just a rectangle in the 3D space with a curious orientation! 😉
                            Or for a direct triming!
                            Etc...
                            A must to have 😄
                              brookefox
                              How about a hint?
                              The erosion is a little further along than the building in question, whose surface is smooth and sleek, more like the flash-flood-water eroded canyons, or Elvis' hair. Maybe yours is like the building in 4 or 5 years.
                              I know this is a modelling discussion and not a 'why bother?' discussion, but that is at the core of my every response...
                              Look at this: all the taffy is decoration and deceit; so many useless calories....
                              hollow spaces holding much hot air.
                              ~ Brooke
                              • pbacotP Offline
                                Postby brookefox on Tue Jul 03, 2012 9:28 pm
                                pbacot wrote:So you have been to my favorite place?
                                How about a hint?
                                [off:27j01tnm][/off:27j01tnm]Probably the biggest showcase of erosion in the world (well it's all erosion I guess), the Colorado Plateau, with myriad geological layers spanning from Bryce Canyon down to the bottom of the Grand Canyon, but here (more specifically) the Needles District of Canyonlands NP in Utah, with the Permian Cedar Mesa Sandstone. This from our last trip. You go for a hike and this is what it is like in all directions.IMG_0168.png
                                Pilou has already won the "model this" competition.
                                Sorry this is so OT but at least we're bumping the thread.
                                  Curvy Loft, FFD, Follow me
                                  seems sufficient
                                  • 2 / 2
