    Need Help!! How to model this kind of form/surface?
    Scheduled Pinned Locked Moved Organic Modelling
    33 Posts 7 Posters 20.6k Views 7 Watching
      sephy
      Dear All:
      i am new to this forum. i found lots of genius here and i did admire you guys for your brilliant intelligence.
      i am currently struggling for modelling the following shape (or say surface)
      i like this kind of surface and do want to know how it could be generated.
      it would be highly apprecited if anyone can help me to solve out this or give me some inspirations.
      thanks!!
      sample model
      • brookefoxB Offline
        brookefox
        Have you tried anything at all?
        Have you any thoughts on the subject?
        Where to begin?
        ~ Brooke
        • dukejazzD Offline
          dukejazz
          Look like a side of a phone book whit a building stuck in it.
          • DareDevilD Offline
            DareDevil
            Just have a look in "Plugins" section in the forum, and look for "Curviloft" or "Extrude tools". You will find some tools to make surfases like that.
              leminilab
              I think this could simply be a matter of using Curviloft (http://forums.sketchucation.com/viewtopic.php?t=28586).
              Draw the front and back curves of the roof based of the image.
              I used BezierSpline (http://forums.sketchucation.com/viewtopic.php?f=180&t=13563#p100509) for that but the native arc tool works too.
              I then used loft by spline to make the junction
              Then you just need to extrude the shape using Joint push-pull.
              Hope this helps.
              Nicolas
              lofted roof.skp
              • "Live every day as if it were your last and then some day you'll be right."
              • "ThomThom rules!!!"
                Shape Bender
                  sephy
                  Where to begin?
                  if i could work out how to model it...than this is not a request post but a tutorial post.
                  anyway, thanks for your reply.
                    sephy
                    plugins are not the issues, i have downloaded and installed all necessary plugins, inclusing those you mentioned.
                    i just need some brilliant thoughts and inspirations,
                    because i know i can model it eventually somehow in some not very clever ways.
                      sephy
                      @leminilab said:
                      [attachment=1:325pwzrb]<!-- ia1 -->lofted-roof.jpg<!-- ia1 -->[/attachment:325pwzrb]
                      [attachment=2:325pwzrb]<!-- ia2 -->lofted roof.png<!-- ia2 -->[/attachment:325pwzrb]
                      Hope this helps.
                      Nicolas
                      thanks you very much nicolas, finally i see a meaningful reply.
                      i got all the plugins, but your model seems not complete yet, and the most difficult part i guess is to model the complicated twisted surfaces, can you give me more inspirations?
                        sephy
                        Shape Bender
                        [attachment=0:1b8to3vv]<!-- ia0 -->shapebend.jpg<!-- ia0 -->[/attachment:1b8to3vv]
                        thanks, but i need thoughts and ideas
                          brookefox
                          It ssems you continue to offer your potential helpers very little, save belittlement. Perhaps a dead end.
                          You still have nothing to show?
                          ~ Brooke
                            sephy
                            ok, lets make it more pratical.continue with nicolas's model, i generated this form by using the joint push&pull and blend shape plugins.
                            but still not good enough,the side surface in the sample model is quite complicated and can't figure out how it can be generated.
                            furthermore, instead of simpliy simulate this form, it would be good to know the basic logic in modelling this kind of shape, so that we can create some similar but different models.
                            lofted roof_1.skp
                              leminilab
                              @pbacot: you're right. I made my first loft very quickly and your approach is much better!
                              Still I made this extrusion with extrude edges by vector from TIG's (Hail to you TIG! ☀ ) Extrude Tools set (http://forums.sketchucation.com/viewtopic.php?f=323&t=25362&hilit=extrusion+tools) and it gives a much better result than Joint Push Pull (Hail to you Fredo6! ☀ ).
                              But again, pbacot's approach is better because he took all the bendings into account.
                              • pbacotP Offline
                                Sephy,
                                I hope some real organic modellers can chime in, but I looked at the model and have a couple of suggestions, in the meantime.
                                The building you have there is small. Try making it the actual size this building would be. It can make a difference to SU, in making all the faces in a curvy shape like this.
                                I would begin by trying to delineate the main shapes in plan then making a 3d outline of the primary edges. Then I'd do the faces one at a time. The top of the roof, the sides, adjoining slopes etc. In the attached file I've modeled the upper roof top and two of the walls, separately, using Curviloft after defining their edges. You can see the edges in the file.
                                Good luck. I'd like to see a tut on this too. This is like car modelling. You might find some tuts on cars, boats, and airplanes.
                                lofted roof_1.skp
                                  sephy
                                  @pbacot said:
                                  Sephy,
                                  [attachment=0:1ehnw2ro]<!-- ia0 -->lofted roof_1.png<!-- ia0 -->[/attachment:1ehnw2ro]
                                  Hi pbacot:
                                  Thanks for your suggestions, i think it's getting closer but still long way to go.
                                  when i look at your model and want to develop it but just don't know how to start, the complexity of the curves really drive me crazy. for example when u look at the curves, they somehow start from horizontal and then twist into vertical and finally merging with other lines...furthermore, the surfaces are not always smooth,it's like some curves are generated
                                  from the surfaces...etc....
                                  i reckon this form is generated by rhino with grasshopper, some kind of parametric modelling software,but what i am interested in is to explore the logic behind this kind of shape.
                                    sephy
                                    [attachment=0:3rudlorg]<!-- ia0 -->lofted-roof-extruded.jpg<!-- ia0 -->[/attachment:3rudlorg]
                                    thanks leminilab,i guess to model this form in sketchup it's more difficult than i think? do u know any other software that can generate this kind of shape in a easier way, that would help as well.
                                    • pbacotP Offline
                                      Sephy,
                                      I have no idea of the logic in the design. I think you need more than one picture for that.
                                      For my example I just quickly drew some curves (well quickly then slowly figured out other curves I needed), and concentrated on the view you have--as I have no idea what the rest of the building looks like. they definitely could have been nicer curves.
                                      You have to decide what your model does then draw that. If you think this derives from some basic form with some sort of computations, thus derived on a computer--that's way beyond me. SU is certainly not the place to start if you are intent on organic forms.
                                      SU wss designed with more boxy buildings in mind 😄
                                      If you just want to approximate the form you may use orthographic projection of the curves in space. Think what the plan would be, extrude that up. Then with tools on surface or other curves define the vertical, z path of the curve on this surface. The walls may not be vertical-- you are just extruding those to give you the horizontal layout.
                                        sephy
                                        Sephy,
                                        Hi pbacot:
                                        Following is the links of this building, with more images:
                                        Just a moment...
                                        (www.dezeen.com)
                                        i personally prefer sketchup if it can generate the similar knid of form as i have been using this software for long time, and that's why i want to find out the possibility, otherwise i will need to learn another software which is quite annoying.
                                        anyway, have a look at the pictures and tell me what u think.
                                          brookefox
                                          I have not studied your link. I looked but the images were small and not very revealing. Consider this: the project was originally sculpted in stiff whipped cream and then photo digitized into a 3D model. From there it went into production, and in some cases, it went viral. Try to sculpt it yourself and proceed as they did.
                                          EDIT: No. I am wrong. It was modeled in pulled taffy, then chopped neatly.
                                          There is, however a wealth of filler available to augment the puffing up of the creamed taffy:
                                          The Museum’s massing becomes a diagram of these geological forces visible in the sedimentary creases abundant on the facade. Using parametric techniques we were able to visualise these layers and texturise the facade to implant an identity which echoes time through its weathering. Emulating these natural landform processes frees a language intrinsically linked with ‘Place’ while hinting of this ‘place’ as a time before human history. This Experiment with an abstracted ‘Growth’ of a building has taken the form of accentuating the landscape, creating distinct man made insertions to augment the existing topography and give the museum its identity.
                                          And therein may lie some important clues to guide us in the resolution of this conundrum.
                                          ~ Brooke
                                            sephy
                                            Hi brookefox:
                                            my idea is there might be two way to generate this form:
                                            the first way is more close to pbacot & leminilab's suggestion. draw some curves first, adjust their position and loft them. this method can generate a kind of simulated shape but will have less control and give you less opportunity to play around and generate another form.
                                            the second way is like what you said: to create a mass first, modify the mass by some commonds, like twisting,stretching? this way might have more control but don't know how to do it in detail.
