πŸ”Œ Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
[Code] Print the transformation matrix
14 Posts 5 Posters 2.0k Views 5 Watching
    dacastror
    Hi, I'm trying to print a transformation matrix, I tried the following:
    pointdd = Geom::Point3d.new 11,22,33 tdd = Geom::Transformation.new pointdd a = tdd.to_a text="-------------------------------------------------------\n" 4.times do |b| 4.times do |e| if ((e+1)%4==0) text << a[e*4+b].to_s+"\n" else text << a[e*4+b].to_s+" "+" "+" "+" "+" "+" "+" "+" "+" "+" " end end end text<<"------------------------------------------------------\n" UI.messagebox( text, MB_MULTILINE)
    I wanted to hear suggestions of more elegant ways to do this. (I wrote several times +" " for failure to escrbir several spaces followed here)
    thank you for your attention.
      danielbowring
      Here's one in your format, although you should probably use one of the ones above (More info here )
      def inspect_transformation_adv(t, args={})
          format = "%.#{args[;places] || 3}f"
          ta = t.to_a.map() {|i|
              format%[i]
          maxlength = ta.max() {|i, j| i.length <=> j.length }.length
          ta = ta.map() {|i|
              i.ljust(maxlength)
          return (0...4).map() {|i|
              (0...4).map() {|j|
                  ta[j*4+i]
              }.join(args[;separator] || ', ')
          }.join("\n")
      >>> point = Geom;;Point3d.new 11,22,33
      >>> tdd = Geom;;Transformation.new pointdd
      >>> puts inspect_transformation_adv(tdd)
      1.000 , 0.000 , 0.000 , 11.000
      0.000 , 1.000 , 0.000 , 22.000
      0.000 , 0.000 , 1.000 , 33.000
      0.000 , 0.000 , 0.000 , 1.000
      >>> puts inspect_transformation_adv(t, {;separator => ' '})
      1.000  0.000  0.000  11.000
      0.000  1.000  0.000  22.000
      0.000  0.000  1.000  33.000
      0.000  0.000  0.000  1.000
        danielbowring
        def inspect_transformation(t)
            ta = t.to_a
            return (0...4).collect() {|i|
                ta[i*4, 4].join(', ')
            }.join("\n")
        >>> puts inspect_transformation(tdd)
        1.0, 0.0, 0.0, 0.0
        0.0, 1.0, 0.0, 0.0
        0.0, 0.0, 1.0, 0.0
        11.0, 22.0, 33.0, 1.0
        Edit: And if you like things to line up:
                format%[i]
            ta = ta.map() {|i|
                i.ljust(maxlength)
                ta[i*4, 4].join(args[;separator] || ', ')
            }.join("\n")
        1.000 , 0.000 , 0.000 , 0.000
        0.000 , 1.000 , 0.000 , 0.000
        0.000 , 0.000 , 1.000 , 0.000
        11.000, 22.000, 33.000, 1.000
        Edit: although that's not the orientation you use
          Is it to visually inspect the matrix of entities, if so you can use this tool: http://forums.sketchucation.com/viewtopic.php?t=44859
            Dan Rathbun
            Here's my simple brute force method:
              def trans_matrix_text( gt )
                return "Not a trnasformation object!" unless gt.is_a?(Geom;;Transformation)
                a = gt.to_a
                w = 3  # width
                a.each{|n| s = n.to_s.size; w = s if s>w }
                l = (w*4)+3
                # create a line output format string;
                fmt = "  | %#{w}s %#{w}s %#{w}s %#{w}s |\n"
                text = "\n"
                text << (32.chr*2)<<151.chr<<151.chr<<(32.chr*l)<<151.chr<<151.chr<<"\n"
                text << fmt % [  a[0].to_s,  a[1].to_s,   a[2].to_s,  a[3].to_s ]
                text << fmt % [  a[4].to_s,  a[5].to_s,   a[6].to_s,  a[7].to_s ]
                text << fmt % [  a[8].to_s,  a[9].to_s,  a[10].to_s, a[11].to_s ]
                text << fmt % [ a[12].to_s, a[13].to_s,  a[14].to_s, a[15].to_s ]
                return text
              end # def
              pt = Geom;;Point3d.new( 11,22,33 )
              text = trans_matrix_text( Geom;;Transformation.new(pt) )
              UI.messagebox( text, MB_MULTILINE, "Tranformation Matrix" )
            I have tweaked my system by copying Consolas font to the font used by dialogs, so I have monospaced text output. (It was easier than tweaking the resources in the executable after each update.)
            πŸ’­
            I'm not here much anymore.
              dacastror
              Thanks for responding, I have helped a lot. πŸ˜„
              me a question arises about the transformations. if I need to apply a transformation to an object but not in the principal coordinate axes, but the coordinate axes of a group (rotated) what should I use?
              (sorry for my bad English)
                You mean, transform an object around its own axis and not world axis?
                  dacastror
                  yes, exactly
                    Create a local transformation and apply with with .transform!( tramsformation ) instead of setting the .transformation matrix manually. Or am I missing something?
                      dacastror
                      How to create a local transformation? I would like to see some sample piece of code to guide me
                        dacastror
                        I wonder if there is any way to know the orientation of a group with respect to the axis of the world
                          You have the model's axes from X_AXIS etc and ORIGIN.
                          Then you have group.transformation.axes or group.transformation.xaxis etc... and group.transformation.origin too...
                          So you can find the relative locations [which are points3ds] and angles between axes [which are vector3ds] - see the methods for those types...
                            <span class="syntaxdefault"><br />point </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">origin<br />vector </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">yaxis<br />rotation </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">rotation</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> point</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> vector</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 30</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">degrees </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">!(</span><span class="syntaxdefault"> rotation </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                              dacastror
                              thank you very much Thomas and Tig that prompt reply! πŸ˜„
                              I will try to implement your suggestions right now
