    Can I have 2 sections planes active?
    5 Posts 3 Posters 162 Views 3 Watching
      CalypsoArt
      I'm a long time SU user. However I've never need this before. Is it possible to have 2 section planes active at the same time? If so, how do I activate them?
        [flash=420,315:2cgsnlpi]http://www.youtube.com/v/aPW6EKMwmjA?[/flash:2cgsnlpi]
        [flash=420,315:2cgsnlpi]http://www.youtube.com/v/-sQ-7dt95yw?[/flash:2cgsnlpi]
        • bmikeB Offline
          bmike
          you can embed an active section within a component and it will stay on / off.
          • bmikeB Offline
            bmike
            here's 3 active at once.
            1 in the overall model space, and then 1 within each of the components shapes.
            Note that the 1 in the overall model cuts through everything.
            The planes within the other components only cut through what is within that component.
              CalypsoArt
              Thanks. What I wanted to do was get a horizontal section through my entire model cutting off the bottom and the top. For what I wanted to do. I made the whole model a component and cut off the bottom with a section cut within the component. Then adding another section cut external to the model gave me what I needed.
