Lumion + xfrog vegetation
hey,
i just discovered the awesomness of lumion, and the possibility to put xfrog trees in my lumion models. so i put together a quick scene of an actual project i'm working on where i have to replant a public park.
the amount of trees and grass in my opinion is mindblowing when you are used to work with components in sketchup and you have to watch every step you take with high detailed trees.do you see a difference between the lumion and xfrog trees?
there has been no post production to this image, pure lumion render. the pathways and the lawn structe will get attention by me later
Hello, sorry, I don´t understand. You put xfrog trees directly in Lumion or you put the trees in Sketchup?
Regards
i downloaded them as .3ds files and imported them into lumion. i tried to put them in sketchup but after one tree the system dramatically slowed down.
in lumion you can place them in realtime and after let's say 300 trees i didn't feel any slowdown of my machine (i guess with a cheap graphics card there will be a slowdown
 ).the nice thing besides that is that you can create a library in lumion and you don't have to re-import the trees for another project.
heey carloh, can i ask how you uploaded the Xfrog trees into lumion, i can't figure it out.
Rick.
Thanks, already try it that way and import xfrog tree really well. The only thing is, xfrog imported don´t have movement (wind) like the lumion trees, but for still images looks very nice.
Thanks again for your attention.
Regards
i have to give a heads up here. most of the newer xfrog trees are too big to put them directly into lumion.
i just bought the europe 3 library and figured out that more than 50% are too heavy for lumion.i now have to look for an opportunity to reduce the polycount using blender or something like this.
As I was saying in the other thread...
the only problem seems to be the import process. once imported i can throw as much xfrog trees in the scene as i want
some new WIP pictures of the project...again no postproduction, raw lumion renders.
when you look at the amout of xfrog trees in the scene you can hear my gpu cooler crying
another...
Edit: just realized the file size, so i erased one picture
Nice images, the grass is also xfog file?
Poor GPU Cooler
Saludos
the grass are lumion models.
Wow , Nice! Can I ask which version of Lumion you are using... Is it Free version 2b7?
hey thanks...i use lumion free 2.1 build 3.
here another WIP, i didn't like the dark grass models, so i tried to build the grass with the photoshop grass brush. maybe i will combine this with some postpro textures, though i even like the result with only the brush.
here is a final picture of one of the areas in the public garden.
only Europe 3 is heavy. built for film use. All other 30 libraries
are much less heavy, (by a factor of 10x) .Really nice work Carloh.
we think to release a video tutorial how to make SU
models from Xfrog 3ds/obj.So they can be used in SU or Lumion.
Thoughts?
i have to re-update my statement that most xfrog trees are to big for lumion. i now have updated my system to win 7 64 bit, bought a new graphics card and added some rams, that now with 8 gb of ram and a geforce gtx 670 i can import every (even europe3) xfrog tree i bought into lumion
  .of course you can't put an infinite amount of xfrog trees in your scene, but as the lumion trees are very easy to handle for the system you can put them in the background to fill the scene. works pretty well for me. i got asked why i don't use lumion trees in the whole scene then...in my case i have to display the correct species i use on my projects, and the amount of species is kind of limited in lumion, especially in the free version.a tutorial for putting xfrog trees in SU sounds pretty good. i tried to import the .3ds files to SU but that seems not to be the right way as it immediately slows down the system? i don't know if theres a better way. i even tried to reduce the poly count with blender without any success.
with my limited knowledge about the whole material i would recommend to use xfrog trees only in your render engine as it works fine with lumion for me.
Did you have to do any work on the 3DS XFrog plant files before importing into Lumion.
I can not make them display properly.Every 3DS Xfrog file that I import into Lumion has Leaves missing.
I have tested about 25 models in 3DS & OBJ & get the same results.The test photo below shows the leaves missing.
The only way that I have made models display properly in Lumion is to import them into Sketchup & the apply the UVToolkit "Frontface Material to Backface" commend & then export as DAE. I even tried to export as 3DS & OBJ after the UV work & it still was missing the same parts.
The resulting file goes from a 6mb 3DS file to a 133mb DAE file!!!Thank you.
http://s790.photobucket.com/user/dbaird1/media/LumionTest_zps1a9233fb.jpg.html
I had the same problem with missing leaves, although i didn't notice it at first because i had no referrence how they should appear and i thought "this is it"
Annyhow i don't use Lumion anymore due to it's lack of realism i was looking for. Now that I purchased the full Maxwell Studio license i can use the Xfrog models withouth any workarounds and also using instancing it is quite nice perfomancewise.
