    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
    • C
      chyn2000
      Hey guys,
      So, I got the ruby extension process to work, but I seem to be running into one little catch... multithreading.
      FYI: I'm using Pelle's C with the options TBD suggested in his SUExt example. I'm on a Win 7 (64 bit) system (though hopefully that won't matter).
      I'm trying to use _beginthread, but using TBD's settings, it seems I have an unresolved symbol '_beginthread'.
      Just to let you know, I am kind of new to multithreading and DLLs. I have created threaded applications, but never a threaded dll.
      Taking an example program that I have gotten to compile and run as a standalone app (pelle's C option multithreaded (lib)), I add the libs, includes and functions required to make it a ruby extension and it suddenly can't resolve _beginthread.
      A couple of modifications to TBD's project settings and I get it to compile and even be recognized by the irb. However, it seems the second the thread tries to run, the whole irb closes.
      The settings I modified to "get it to work" was:
      Runtime library from multithread (dll) to multithread (lib)
      and turn off "Omit default library in object files"
      Any ideas?
      Thanks,
      Reg
      // general Windows
      #pragma comment(lib, "kernel32.lib")
      #pragma comment(lib, "gdi32.lib")
      #pragma comment(lib, "user32.lib")
      #pragma comment(lib, "shell32.lib")
      #pragma comment(lib, "advapi32.lib")
      // Ruby
      #define HAVE_ISINF 1  // isinf macro redefinition workaround
      #pragma comment(lib, "msvcrt-ruby18.lib");
      // DLL
      #pragma comment(lib, "crt.lib");
      #include <stdio.h>
      #include <windows.h>
      #include <process.h>         // needed for _beginthread()
      // Ruby headers
      #include "ruby.h"
      void  silly( void * );       // function prototype
      // De fining a space for information and references about the module to be stored internally
      VALUE KMRH = Qnil;
      int j = -1;
      // our function
      VALUE method_display_model(VALUE self, VALUE input)
          // Our program's first thread starts in the main function.
          printf( "Now in the main function.\n" );
          // Let's now create our second thread and ask it to start
          // in the silly() function.
      //    _beginthread( silly, 0, (void*)12 );  //Commented out to see if the program would stay alive and it does
          // From here on there are two separate threads executing
          // our one program.
          // This main thread can call the silly() function if it wants to.
      	while(j != 0)
          	silly( (void*)j );
      		j--;
          Sleep( 10000 );
      	int i = NUM2INT(input);
      	return INT2NUM(i + 1);
      // The initialization method for this module
      void Init_KMRH(void)
      	KMRH = rb_define_class("KMRH", rb_cObject);
      	rb_define_method(KMRH, "display", method_display_model, 1);
      void  silly( void *arg )
      	int k = 10;
      	while(k-- != 0)
      //    	printf( "The silly() function was passed %d\n", (INT_PTR)arg );
          	printf( "The silly() function was passed %d\n", k );
        That's way beyond me. I've not dealt with threading at all. But I'll be keeping an eye on this as it something I might want to do in the future.
        • C
          chyn2000
          So, I have to apologize for wasting your time...
          First thing I need to do (yet again) is RTFM.
          The answer to threading is incredibly simple:
          becomes
          rb_thread_create( silly, (void*)12);
          found it on:
          http://ruby-doc.org/docs/ProgrammingRuby/html/ext_ruby.html
          So, if you will excuse me, I need to go beat myself half to death...
            You will not get any joy from using Ruby threads. They are "green" threads. It's just Ruby dividing up the tasks itself - not the system. So making a thread in Ruby will not prevent SU from freezing.
            http://www.igvita.com/2008/11/13/concurrency-is-a-myth-in-ruby/
            • Dan RathbunD
              Dan Rathbun
              And Daniel Berger's win32-thread package that wraps native threads is still Alpha and unstable (AFAIK.)
              I'm not here much anymore.
                jefftrull
                I'm on to the next challenge now... building for the 1.8.7-p334 version my colleagues prefer (better compatibility with certain gems). Unfortunately this one was built with with mingw, and my VS2010 build flow that worked for 1.8.6-p287 (mswin) is not successful here. I have the following results:
                1. build against 1.8.7-p334 built from source with VS2010: compile succeeds, load fails with missing dll msvcrt-ruby18-vc100 (or something like that). If I supply the dll, Sketchup crashes.
                2. build against 1.8.7-p334 one-click install (mingw): compile fails. Lots of warnings about win32.h and missing ruby API functions
                3. hybrid build pointing includes to mswin build of 1.8.7-p334, library from mingw one-click: link error
                I'm under the impression that because dll's use the C API it should be possible to load a VS2010-generated extension into a mingw-built Ruby. Is it a hopeless cause?
                Thanks,
                Jeff
                  jefftrull
                  Today I made a startling discovery: the plugin I built under VS2010 against the 1.8.6-p287 mswin Ruby will load and run without changes in the 1.8.7-p334 mingw build. So the Ruby version and compiler both mismatch, and yet everything works. I'm dumbfounded but delighted, and my previous question is now moot.
                    πŸ‘ πŸ˜„
                      @thomthom said:
                      Btw, does anyone know how one can make extconf.rb and make/nmake output their files to a given folder? I'd like to make it so that each platform outputs its generated files to separate directories.
                      Anyone know how to achieve this?
                      Making it so that when I build and compile under Windows everything is placed in a "win32" folder and "osx" when using OSX?
                      Or rather, to clarify, I know how to do conditionals - just don't know how to control where the generated files are output.
                      • Dan RathbunD
                        Dan Rathbun
                        and you are compiling from the commandline, not from within the Visual Studio GUI interface, correct ?
                          Currently using nmake that comes with MS VS C++.
                          And I'm using a extconf.rb with mkfm to generate the makefile.
                            Is it possible to build an Ruby C Extension under Windows that doesn't require additional libraries? When using Visual C++ to build the extensions require the C++ runtime library.
                            • tbdT
                              tbd
                              yes. my old example did that. best is to check the DLL imports section to see what functions it requires
                              http://plugins.ro
                                Ah, the Pelles C project! Is it possible to use to to just compile the C source without creating a project? (just trying to find a solution without creating too many extra project files.)
                                • tbdT
                                  tbd
                                  the .ppj file is just a collection of commands. you can easily convert it to a .bat file if you dont want to have extra files (remember to create the .def file for the .dll link)
                                  http://plugins.ro
                                    Do you remember the cause of the C:\ruby\src\ruby-1.8.6-p111\missing.h(71): error #1050: Redefinition of macro 'isinf'. error? And can you explain what your workaround actually do?
                                    Trying to set up a project myself so I actually understand this.
                                      And why is the macro redefinition just a warning for this guy, but an error in Pelles C?
                                      https://github.com/barrie0482/rrdruby_win32_build/wiki
                                        hm... there is an msvcrt-ruby18.dll in the SketchUp folder - can I make my Visual Studio C++ project rely on this instead? So when the C Extension loads under SketchUp Ruby the runtime is there - installed by SketchUp. ??
                                          isinf is already defined in PellesC libraries so there is no need to include that file again.
                                          But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
                                          Building hello_world.obj.
                                          Use <stdlib.h> instead of non-standard <malloc.h>
                                          C;\ruby\src\ruby-1.8.6-p111\missing.h(71); error #1050; Redefinition of macro 'isinf'.
                                          *** Error code; 1 ***
                                          Done.
                                            http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
                                            When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
                                            • 5 / 9
