    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Edit materials from code
    11 Posts 4 Posters 454 Views 4 Watching
      dacastror
      Hello
      I have a question
      How I can edit a previously created materials? (from code)
      and how I can change the display name?
      • Dan RathbunD Offline
        Dan Rathbun
        Access the material object, via the Materials collection.
        Then change it's properties. (See the API dictionary for examples, on both.)
        I'm not here much anymore.
          Dan Rathbun
          I just tried changing the display name for a new file, opened with the Susan component.
          Her trousers have material 'jean blue'
          At the console:
          mats = Sketchup.active_model.materials
          #>> #<Sketchup;;Materials;0x656d2f8>
          m = mats['jean blue']
          #>> #<Sketchup;;Material;0x6525214>
          m.name.inspect
          #>> "jean blue"
          m.display_name.inspect
          #>> "jean blue"
          m.name="bluejeans"
          #>> "bluejeans"
          #>> "bluejeans"
          And I visually see in the Materials Inspector that the display_name has indeed changed.
            dacastror
            thank you very much, functioned to change the display name šŸ˜„
            I looked at the API dictionary do not understand,
            could you give me an example?
            such as changing the color of the material 'blue jean' to red
              dacastror
              I have understood
              mats = Sketchup.active_model.materials m = mats['jean blue'] m.color=[180, 0, 0]
              I am new to this,that good there are good people willing to help, thank you very much Dan
              (I know very little English)
                dacastror
                I have another related question,
                if I have a cube, each side painted a different color and then create a group or component, how I can access the list of materials the component or group to modify these materials from the code?
                Would greatly appreciate a simple example of this, I could not find him anywhere
                  Any group [or a component-instance] can themselves have a 'material' - e.g. group.material if it's ' nil' then it has no material, however if it has a material any faces within the group that 'have no material' will display with that group's material [although they still have ' nil' material individually, they will display with the group's material].
                  The faces [and edges for that matter] inside a group.entities can have materials [ face.material] - or ' nil' if none.
                  Therefore, to find the materials used inside a group [or component definition found from its instance], make a collection of the group.entities faces and then iterate through those faces and collect each face.material, use .uniq! on that array, so you have only one of each; then iterate that array of materials and make a list of their 'names' etc etc...
                  šŸ¤“
                    Note: Material.name is the internal ID name - while Material.diplay_name is what SU display in the material browser (exposes to the UI).
                    For instance, you cannot use Material.display_name as a key in the Model.materials collection - it will fail in some circumstances (for instance when the name is wrapped in [])
                    Read more: http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/
                      Dan Rathbun
                      Diego... see: Ruby Newbie's Guide to Getting Started
                        dacastror
                        wow, is more complicated than I expected, I doubt that achieves do with my current knowledge of the Ruby API, I guess I'll have to wait a while thank you very much Dan, Tig and Thomthom for guiding me
                        šŸ‘
                          dacastror
                          this is what I have achieved so far
                          entidad = %(#FF8000)[Sketchup]%(#0040BF)[.active_model.selection][0] curretmaterial = entidad%(#0040BF)[.material] nameM = curretmaterial%(#0040BF)[.name] curretmaterial%(#0040BF)[.color]=[102, 0, 51] curretmaterial%(#0040BF)[.name]=%(#BF8080)["nuevo tono"]
                          I shall be able then apply the recommendations
                          (sorry for bad English)
