⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
V-Ray render stays black
Hey
I'm having problems with vray rendering.
I use vary lights in my model and when I try to render it the window stays black. This is both on Mac and Windows.
Does somebody know what the problem is, because google couldn't tell me.Wesley
Hi, if You are uuing physical camera check Your ISO / Aperture / Shutter time.
Maybe You don't have enough light in Your model if You are using combination of ISO 100, Aperture 8 and Shutter 1/200 ( standard settings ?)
Hope this helps
Matt -
or your lights are simply not bright enough; right-click any light and choose 'Vray for Sketchup' > 'Edit Light'. You'll get a panel where you can change its intensity.
