    šŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Tutorial] Network Render in Thea
    extensions
    10 Posts 4 Posters 6.5k Views 4 Watching
    • rodrigonotorR Offline
      rodrigonotor
      I try to explain my workflow to make a network render in Thea
      First of all, like I explain in the topic for v-ray, http://forums.sketchucation.com/viewtopic.php?f=322&t=38908&hilit=+render#p343511 we have to be sure that PC“s are conected in the network also firewall persmisions are setup. Default port for Thearender is 6200
      Ok, if we are sure, proced in this way:
      Already done this, have to install Thea in cliente mode, with serial for cliente node (not normal serial). Thea render start in client mode.
      http://www.sketchando.net/foro_imagenes/net_thea_001.jpg
      After this, in Therender Server go to menu->Help->Server Beacon. This transmit the information from server to clients nodes.
      http://www.sketchando.net/foro_imagenes/net_thea_002.jpg
      In each one of clients click in Configure and the Icon that look like WIFI
      http://www.sketchando.net/foro_imagenes/net_thea_003.jpg
      This step search the server and when the client find, click ok
      http://www.sketchando.net/foro_imagenes/net_thea_004.jpg
      Click Start and the client wait for the server information
      http://www.sketchando.net/foro_imagenes/net_thea_004a.jpg
      Back to server machine and the client are connected click in cancel
      http://www.sketchando.net/foro_imagenes/net_thea_005.jpg
      In the render option windows in network select server
      http://www.sketchando.net/foro_imagenes/net_thea_006.jpg
      Start render
      http://www.sketchando.net/foro_imagenes/net_thea_006a.jpg
      open a window "preparing Project File" in the server and in client (or clients) side "opening temp.pack.thea"
      http://www.sketchando.net/foro_imagenes/net_thea_007.jpg
      http://www.sketchando.net/foro_imagenes/net_thea_008.jpg
      in this example I only conect one client to server: darkroom->network
      http://www.sketchando.net/foro_imagenes/net_thea_009.jpg
      Client side start the render job
      http://www.sketchando.net/foro_imagenes/net_thea_010.jpg
      Server side show clients and % of work
      http://www.sketchando.net/foro_imagenes/net_thea_011.jpg
      Regards (Saludos)
      El mismo tema solo que en espaƱol: http://forums.sketchucation.com/viewtopic.php?f=52&t=45792#p409061
      • [Sketchando.net](http://foro.sketchando.net/portal.php) • www.arqcad.net •
      • N Offline
        notareal
        You might want also look into Thea Render network rendering tutorials (pdf documents) under http://www.thearender.com/cms/index.php/resources/render-farms.html
        TheaNetworkRendering.pdf is pretty much like this tutorial
        TheaRenderFarm.pdf contains advanced option, including use of command line
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
          rodrigonotor
          Notareal, in fact I take most of the steps from PDF Tutorial and added some steps I considered important (like install Thea with node serial). My primary objective is post in spanish forum, for non-speak englihs people but once done in Spanish, I thought, why not post it in English also.
          Regards
          • N Offline
            notareal
            Using node license is good to emphasis. Also if one likes to create some more automated nodes, it's good to learn to command line options. One could even run node computers in a "kiosk" mode and automatically load Thea clients šŸ˜„
              rodrigonotor
              Can you explain this issue? I don,t understand.
              Thanks in advance
              • N Offline
                notareal
                I did mean that with a little afford you should be able to automate client computers, so that when you boot them, Thea node is up and running, ready for rendering without a need for you to start Thea manually (or even physically access on client)... so sort of "kiosk mode". Naturally this is up to your client OS and how you set up the framework for a render farm, anyhow just you look trough command line options, all is there...
                  rodrigonotor
                  Ok, thanks, I look in the tutorial.
                  regards
                    gargon
                    Buenos dĆ­as.
                    Te escribo porque no se a quiƩn acudir y no como solucionar mi problema y te agradecerƭa mucho que me ayudases.
                    Acabo de adquirir thea render 1.4 y estoy intentando renderizar en red, pero no consigo que se conecten los equipos.
                    Abro thea en el primer equipo y le doy a server beacon y despuƩs voy al siguiente equipo, abro thea y no se abre en modo cliente, se abre normal, con lo que no consigo renderizar en red.
                    Muchas gracias por tu ayuda.
                    Un saludo y feliz navidad.
                      rodrigonotor
                      Hola Gargon, creo que tu problema es, que en la computadora que estas usando como cliente, le pusiste el numero de serie de Thea y no la de cliente.
                      • KrisidiousK Offline
                        Krisidious
                        Any way to get this to work on a dedicated server that is not on your network?
                        By: Kristoff Rand
