    Integration tool by using paste in place
    15 Posts 3 Posters 951 Views 3 Watching
    • N Offline
      njeremy2
      this line doesn't work :
      inst=group.entities.add_instance(tempgroup.entities.parent, tempgroup.transformation*(group.transformation.inverse))
      What "transformation" module is use for ?
      Because in "Automatic Sketchup.pdf" transformation* doesn't exist.
      It's write : The transformation method is used to retrieve the transformation for the group.
      But what transformation ?
      I'm stuck here, I'm coming back tomorrow
      • TIGT Online
        What error messages do you get ?
        Any group/instance has a transformation.
        We use it here to get the temp group into the group in the same relationships ...
        • N Offline
          njeremy2
          There is no error messages but this line isn't executed.
          %(#BF0000)[model = Sketchup.active_model
          things = model.selection.to_a
          UI.messagebox "initialization ok"
          	tempgroup=model.active_entities.add_group(things)
          	UI.messagebox "add group ok"
          	UI.messagebox "add_instance ok"]
          I put messageBox each line to see if the code is executed or not.
          "add instance ok" didn't appear so I guess is not working
          Into outliner, I see the plugin create a new group for my thing which is selected but it isn't integrated inside the initial group.
          http://img204.imageshack.us/img204/7599/75074987.png
          http://img268.imageshack.us/img268/7420/addgroup.png
          http://img20.imageshack.us/img20/7563/copied.png
          • TIGT Online
            Where in your code are you getting 'group' as a reference to the group into which you want to move the selected 'things' ?
            It will be set by picking a group with the Tool, but as a test now you can 'preselect' it earlier by highlighting the 'group' and having an extra line early on like this...
            model=Sketchup.active_model **group=model.selection[0]**
            then deselect the 'group' and select the 'things' to be added, then continuing with the code...
            things = model.selection.to_a ...
            If you do it line by line in the Ruby Console what is the result?
            I have just tested it this way and it works perfectly...
            • N Offline
              njeremy2
              Here is my file,
              When I test it, I select my drawing which I want to add in group.
              Then this plugin create group with that drawing put it cannot execute the next line (with transform)
              I didn't test it in RUBY console into sketchup
              file reupload at 11h49 - France
              testintegration.rb
              • TIGT Online
                This is messed up...
                Run it with the Ruby Console open to see all of the error messages...
                You click the mouse-button, have a pick_helper but then set @group to be the the first item in the model.selection which is of course one of the things to be added into the 'group' ???
                Also you haven't defined 'model' in the code so it'll fail at that step anyway...
                Try something like this:
                def onLButtonDown(flags, x, y, view)
                  pickHelper = view.pick_helper
                  pickHelper.do_pick(x, y)
                  allPicked=pickHelper.all_picked
                  @group = nil
                  allPicked.each{|e|@group=e if e.is_a?(Sketchup;;Group)}
                  unless @group
                    UI.messagebox("That's NOT a Group !")
                    return nil
                  self.integration()
                  Sketchup.send_action("selectSelectionTool;")
                The pick_helper stuff needs recasting...
                I added an 'exit' to the select tool.
                Also you should trap in 'activate' for an empty selection as they'd be nothing to tempgroup/add_ later...
                Here's an adjusted version that works...
                Also I'd also call the tool class something like 'Jeremy_integration_tool' ???
                ###testintegration.rb
                • N Offline
                  njeremy2
                  Oh wooow! thank you TIG ! πŸ˜„
                  It works great ! you are fabulous ! πŸ‘
                  When I look the code, it's different than what I tought !
                  Just a little question, if you initialise "@group=nil" is it the same if you do that : "@group=[]" ?
                  Because after picking, you put each group you found inside "@group".
                  Voila ! thank you so much πŸ˜‰
                    No - @group=[] == @group=Array.new
                    • TIGT Online
                      You must set any reference that you want to use later outside of a block - so when it is set inside the {} block it is still accessible to the rest of the code.
                      @group=nil sets an empty reference
                      BUT
                      @group=[] makes an empty array.
                      In the {} IF there's a selected group then @group is set to be it @group=e if....
                      Otherwise it stays as ' nil'.
                      Then the test
                      unless @group ...
                      says if group is ' nil' you didn't pick on a group, so we exit with a message...
                      The current code doesn't 'insert' the group into @group, it makes it its reference.
                      However, if you were 'collecting things' into an array initially made as groups=[] ... then you would use
                      groups << e if... rather than the singular @group=e if..., that way you get a 'list' of matching objects...
                      • N Offline
                        njeremy2
                        oh ok!
                        Thanks to all ! I understand now πŸ˜„
