    Component axes visibility
    6 Posts 3 Posters 403 Views 3 Watching
    • andybotA
      andybot
      I run into this issue every now and then. Seems to happen when I use the "align" ruby. All my components in the model get a visible axes. I can't for the life of me figure out how to turn it off. I'm sure it's a simple solution, but there's not anything that I could figure out in adjusting the drawing style...
      axes on:
      how it was before:
      • mitcorbM
        mitcorb
        Evidently "Align" calls up visibility of component axes, but doesn't uncall after the alignment. Maybe it did in the past?
        You of course know that Model Info>Components there is a tick box for Show component axes. Just thought I would mention that.
        • andybotA
          andybot
          It may be getting messed up during undos, it normally works OK.
          Thanks, that's where I didn't look... 👍
          • mitcorbM
            mitcorb
            I failed to mention that I like the model example. Nice work.
            • andybotA
              andybot
              Thanks Tim!
              By the way, I noticed with the align tool - it specifically happens if I cancel out in the middle of the operation (presumably before it has a chance to call the component axes hidden again.)
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                You can control this using Window menu --> Model Info --> Components.
                Check or uncheck the last box at the bottom that is labeled Show component axes.
                Just ideas.
