    Splitting a spiral line into equal segments
    23 Posts 3 Posters 1.6k Views 3 Watching
      davecon
      use BezierSpline
      http://forums.sketchucation.com/viewtopic.php?t=13563
      once installed, right click on the spiral then go:
      BZ convert to -> polyline segmentor (to divide by # of segments)
      or polyline divider to divide by desired segment length
      I have that installed but I don't seem to have those options. My only options from "BZ convert to" are "polyline" and "polyline divider for animation". If I try the divider for ani option, it places marks on the spiral but not at the specified intervals and they disappear if I switch to another tool (such as Draw Cpoint)
        Absolutly no problem with your file! โ˜€
        Then Click the Base of the vertical Group and move without release the Blue cross cursor to the start of the spiral!
        • jeff hammondJ Offline
          hmm.. strange.. in the case of your spiral, first select the curve then right-click -> explode curve.. now, with all the segments selected, right-click again then all the BZ options should be available.
            Before I have seen your file ๐Ÿ˜„
              @ Jeff
              What is the workflow of the Bezier Polyline Segmenter ?
              Seems You must by hand make 50 clicks on the spiral! ๐Ÿ˜ฎ
              Or I miss something ๐Ÿ˜„
              The other polyline Divider by measure is not very accurate and you must make a division and don't end exactly on the end following number of segments! ๐Ÿ˜’
              (and where are the intersections of the divisions ? ๐Ÿ˜‰
                @ Jeff
                i think you're missing something ๐Ÿ˜‰
                just enter the number segments in the dialog and click 'OK'โ€ฆ then click the mouse in a blank part of the screen (when the green arrow says done/exit tool)
                right.. there are times when that's needed.. for instance, building a stud wall that's 120" long with 16" centers.. dividing with bezierspline will layout at 16" then leave the odd segment at the end.
                  Seems there is a glitch somewhere ๐Ÿ˜’
                  I have not that ๐Ÿ˜„
                  Maybe an old version
                  Curve is redrawn with the numbers of segments asked ?
                    correct.. it's a handy command that i use quite often..
                      davecon
                      @jeff this has solved my issue ๐Ÿ˜„ My mistake was thinking that it was going to create construction points on the spiral, when it was actually changing the length of each component part to 50mm and so I just had to snap to the endpoint of each short length.
                      Many thanks to both of you for helping me to get this sorted out.
                        Explode curve was the trick! ๐Ÿ˜ณ
                        yeah.. you usually don't have to explode first.. i'm not sure why this spiral requires it ??
                        the spiral in the images i posted above was drawn with curveMaker and it didn't require exploding first ..
                          Ok but that's dramatically transformed ๐Ÿ˜„
                            A more mystery one! ๐Ÿ˜„
                            And the original curve is not "divided" by 50 on its path!
                            Maybe at the start but surely not at the end! ๐Ÿ’š
                            About strictly the question asked i prefer my solution! ๐Ÿ˜‰
                            Each segment is equal length and can be used for redraw the same Spiral! ๐Ÿค“
                            • 2 / 2
