    Unwrap rendered textures for SU
    17 Posts 6 Posters 2.4k Views 6 Watching
    • iichiversiiI Offline
      iichiversii
      I'm not sure if this exsists but my question is-
      Is it possible to unwrap a rendered texture of an object or component where it can be reapplied into SU to replace texture prior to rendering, for example, if I render a house, the render engine will render all visible textures as a flat 2D texture, unwrap it so its flat and not a perspective view of the image, the house will be rendered from all angles, once this is done you can replace the texture with the rendered texture automatically.
      If it does exist what software do I need and how do I do it, please point me in the right direction 😄
      Thank you in advance
      Bring on the Rain...
        This would be called "texture baking" although I am not sure why unwrapping and then re-wrapping would be needed. LightUp (working inside SU) can do this and then export to FBX which you can import to SU afterwards. The texture won1t be a single, unwrapped texture though if I am correct. Maybe that's why you need this feature? To end up with a single material?
          I'm not sure why you'd want to do it... 😒
          But you can combine several textured materials into one [context-menu]
            Blender
              iichiversii
              Ok nearly there, see the image above, note the brick texture, if I render this we get a realistic brick structure which will have bump map, so on, replace the original brick texture with the rendered texture, would this not give the effect of a more realistic brick structure in SU?
                I don't think so ?
                I'm still unclear on the workflow, intentions, end-result hoped for etc...
                  iichiversii
                  Oh sorry, I need to import into unity3d and would like to render the image first and reapply it to the model as a new texture, to try and get a better result, unity doesn't render the textures that well so I'm looking into rendering a texture before importation to see if the texture improves within unity
                    iichiversii
                    In other words I'm just experimenting 😄
                      Now that's exactly LightUp. It does not only bake textures (and not only with bumps and all but even lighting) but also can export to Unity with these baked textures.
                      [flash=600,480:3cgyb2fd]http://www.youtube.com/v/eNI2RjNsRwY[/flash:3cgyb2fd]
                        chad3006
                        If you want to do it on the cheap and don’t mind a little elbow grease, you can use SU and Kerkythea. I’ve done it by changing the camera settings in SU to “Parallel Projection,” and having the lighting set, then exporting to Kerkythea via Kerky’s plugin. The cool thing is that Kerkythea will preserve the camera and lighting settings. You apply textures in Kerky (if you want to) and render a parallel projected picture. Do that for all perspectives (top, front, side, etc).
                        At this point you can edit them in Gimp or something like that (if you want to.) Then go back to SU and use the pictures you just rendered in Kerky as your new SU textures. They’re poor man’s “baked” textures then. Of course this is easiest with models that have flat surfaces like a house or something and it’s much more complicated with more complex models.
                        Kerkythea link: http://www.kerkythea.net/joomla/
                        Edit: I just remembered there is something called Model Converter X that will combine the SU textures into one file to minimize drawcalls in games, etc. http://www.fsdeveloper.com/forum/downloads.php?do=file&id=83
                          iichiversii
                          You answered a question there I had pondering around in my head for sometime about draw calls, so does texture baking reduce the number of draw calls per scene? Or does it complicate the scene more?
                          it's something I had posted recently about understanding draw calls which I'm new to, unfortunately most sketchup artists never heard of the term draw calls
                          • numbthumbN Offline
                            numbthumb
                            Maybe because most of them aren´t interested in game development 😕
                            Anyway, have you tried Unity Developer Network?
                            And since persistence and talent is something you don´t lack, experimenting with other 3D modeling software won´t hurt. It can actually be fun. Even Blender 😄
                            Comfortably numb...
                              Damien would have learnt Blander by now if he took heed to the advice numerous members suggested.
                              SketchUp does exactly what is was meant to do. It doesn't want to be a character animation application or a game development tool. Sure you can model assets in SketchUp but you will run into difficulty as soon as you start importing meshes into other applications if your mesh isn't primed correctly.
                              For those who's budget is zero Blender is extremely powerful and the level of tutorials out there is immense. v2.6 is the best yet and it's UI overhaul make it super simple to adopt to.
                              3 months invested in Blender will translate to other commercial applications also. So your time spent with it isn't in vain.
                              I'll say it one last time. Learn Blender. You won't regret it.
                                iichiversii
                                Lol, I am Rich, iv made a lot of progress so far, I took your advice don't you worry I'm learning other program's too, I still enjoy sketchup more and always trying to find new ways to use sketchup, I also understand Not many SU users know the term draw calls and it's not just for game development, draw calls would also be needed to be taken into consideration when developing a 3D visualisation tool on mobile devices, it's something that I learnt in a study of viewing SU models via my iPhone, I like to test the boundaries and see how to make something work that does not work, it's the buzz of making things work, like for example my character models which were created inside SU but created in a way it would work effectively once applied to another outside program like blender, Houdini, 3D max and so on, it's the trill of getting results and a better understanding of how to model effectively and perfect my technics. 👍
                                  iichiversii
                                  That download of ModelConverterX doesnt seem to work for me, everytime i launch it it crashes, very strange and its a shame as it looks like a promising tool 😞
                                    chad3006
                                    Hmmm. I've used it in XP and Win7 both without any issues. I think it does require MS .NET framework -- if that helps.
                                      iichiversii
                                      Yeah I installed MS .NET framework, seems as thu the download is broken, once I download it it causes an error, I'll have a look at it again tonight and see if I can fix it
