    Fastest way to retrieve the corners that make up a face?
    9 Posts 4 Posters 607 Views 4 Watching
      steve r
      I need to know the coordinates of the corners that make up selected faces. Right now I'm doing something like this:
      for face in selection
      corner.insert face.bounds.corner(0)
      corner.insert face.bounds.corner(1)
      corner.insert face.bounds.corner(6)
      corner.insert face.bounds.corner(7)
      Where selection is all of the currently selected entities (which have been checked to only be faces) and corner is a previously empty Set. Obviously, using the BoundingBox only works if the faces are oriented exactly along the axes of the model. I know I can get the edges of each face, and then get the vertexes that make up the edges, then convert those to Point3d... but that seems really slow. Since I need to do this a lot (over 2,500 times in one example model) I'm looking for the fastest way to do this... any ideas?
        This will only work on rectangular faces ?
        face.vertices returns an array of each actual corner [vertex].
        vertex.position returns the point of a vertex.
          steve r
          Oh jeez, that seems pretty obvious now. Thanks!
          • Dan RathbunD Offline
            Dan Rathbun
            so take it to a 1 liner (where your Set is named corners, and need not really be empty):
            corners.insert( *face.vertices.map{|vertex| vertex.position } )
            NOTE: The API does not say so, but the insert() method can take multiple args separated by commas.
            The map method returns an array, so we can use the * expand/contract (I call it the "accordian",) operator, to convert the array to an argument list.
            I'm not here much anymore.
              Doh!!! 😲
                Dan Rathbun
                @thomthom said:
                Doh!!! 😲
                Which brings up a compatibility issue between Sketchup's Set and Ruby Set.
                The Ruby Set#add() method only takes 1 argument, so I cannot just alias add as insert in my set_fix.rb file.
                  steve r
                  Wow, well, that's a little over my head, I'm just learning Ruby, so I'll have to dissect that. Thanks!
                    Dan Rathbun
                    Ok well assigning values to references may help you understand, but it will slow down the loop.
                    (Also it's confusing both to read, and slows down Ruby interpreter, when you use ref names that are the same as method names.)
                    So:
                    coord = Set.new()
                    for f in sel
                      verts = f.vertices
                      posary = verts.map {|v| v.position }
                      for p3d in posary
                        coord.insert( p3d )
                    The only persistent reference you really need is coord.
                    Now simplify a bit:
                    coord = Set.new()
                    for f in sel
                      verts = f.vertices
                      coord.insert( *posary )
                    The * operator will expand an array into an argument list, or (if used within method definition's parameters,) compress the remaining argument list into an array. We are using the former, in this example.
                    So, simplify a bit more:
                    coord = Set.new()
                    for f in sel
                      verts = f.vertices
                      coord.insert( *verts.map{|v| v.position } )
                    And again:
                    coord = Set.new()
                    for f in sel
                      coord.insert( *f.vertices.map{|v| v.position } )
                    And finally:
                    coord = Set.new()
                    sel.each{|f|coord.insert(*f.vertices.map{|v|v.position})}
                    ADD: For some reason, for .. in loops are faster than each block methods.
                      They may be faster - because they don't create a local variable scope - the scope is shared with it's parent scope. Creating variables in Ruby is an expensive operation, so if you create variables within an each loop it's created every time, within a for loop it's reused.
