    Count verticies?
    7 Posts 4 Posters 478 Views 4 Watching
    • opalO Offline
      opal
      might someone know of a plugin that counts the verts in a model or portion of a model? I've found the count triangles plugin.. and the mark verts plugin.. cannot seem to find anywhere to count the actual verticies.
        You can count the vertices with Vertex Tools - but if that's all you want to do then it's probably not the right tool for you as it's a vertex editing suite which isn't free.
        I thought there was such a utility, but I can't seem to find it right now. Would be trivial to write though.
          Ah - there we go - thanks Pilou.
            Take the Count Faces by Sides by Fredo 6 inside this Tools Package β˜€
            There is inside also vertices count! πŸ˜‰
            • opalO Offline
              opal
              has vertex tools already
              will explore that further.. and the other one too
              thanks you two
              ETA.. I have FredoTools too.. just had not explored it far enough
              again.. thanks
                Notice the little information panel displaying total vertices in the current context - and selection.
                http://www.thomthom.net/software/vertex_tools/manual/user_interface#information_panel
                • sdmitchS Offline
                  sdmitch
                  You can find a simple vertex counter of mine here.
                  404 Not Found
                  (forums.sketchucation.com)
                  http://sdmitch.blogspot.com/
