    Qt4 GUI in Ruby for Sketchup plugin's
    17 Posts 6 Posters 3.4k Views 6 Watching
    • Dan RathbunD
      Dan Rathbun
      @thomthom said:
      The Set class in SketchUp conflicts with the Set class in the Standard Library for instance.
      I just happened to be working on a fix, as I need to use a gem that requires the standard Set class.
      see: http://forums.sketchucation.com/viewtopic.php?f=180&t=45443#p406187
      I'm not here much anymore.
        Jim
        Just wanted to point out wxSU. Similar idea to yours, but uses wxWindows. Perhaps there is some ideas that could be applied to Qt4.
        http://wxsu.sourceforge.net/
          Didn't SU4Thea use that at some point - and it caused conflicts and issues. Messed around with lots of stuff, even attached hidden windows to the SketchUp window etc...? Or was that something else?
            MOGhouse
            That is a very good idea - will have a look πŸ˜„
            • Dan RathbunD
              Dan Rathbun
              Yes thomthom, WxSU creates an invisible toplevel windowframe around the SketchUp application window, so that Wx messages can bubble up to that window object and be processed. (It changes the SU app window class to be a child of this invisible window.)
              I wonder if this can cause problems for plugins that use EventRelay, or plugins that are searching for window objects using Win API calls via Win32API ??
                Yes it can.
                  MOGhouse
                  Hi guys - thank you for your input.
                  It might be that Dan is right and a complete ruby installation is needed at runtime, but that is not the easy lightweight solution I was hoping for.
                  Here is what I was hoping to achieve.
                  main.rb cotains
                  require 'your_ui.rb'
                  and
                  require 'Qt4'
                  I want to track down the files/libraries that are sought by
                  require 'Qt4'
                  The files required by Qt4 is placed inside the sketchup tree, maybe in /Resources/Qt/, as standalone dependencies for plugin's.
                  Then require the files directly with a path to the files... /Resources/Qt/Qtcore
                  As I understand Sketchup runs its own ruby interpreter 1.8.6, and I want the interpreter to run the GUI also.
                  Should this work? or is it a really bad idea?
                  Sorry, I have a stupid question - I can't get my head around the require.
                  When you require 'Sketchup' or 'Qt4' - what actually happens, which files are actually sought? - I sure there is an easy way to track them down, I just can't find it .... πŸ˜•
                  Can anyone give me a hint.
                  • Dan RathbunD
                    Dan Rathbun
                    The require() method is defined in mixin module Kernel, which is "mixed into" class Object, using the C-side of the include method.
                    Therefore... since ALL objects in Ruby are subclasses of Object, EVERY object's pedigree will contain Object and Kernel. You can see this with the ancestors() method. Subclasses inherit their ancestors methods, but can be overridden locally within a class or module, or locally undefined (which is rare.)
                    You should read up on the Kernel.require and Kernel.load methods.. and understand how require uses the global arrays $LOAD_PATH (aka $:,) and $LOADED_FEATURES (aka $".)
                    Get the Standard Ruby 1.8.6 Reference (CHM) here, or access the online web editions for the Core and Libs.
                    • Dan RathbunD
                      Dan Rathbun
                      Bad idea.
                      1) the Resouces path is a application OEM path and should remain "hands off"
                      2) it is very difficult to install anything into that path
                      Ruby libraries, other than a few win32ole.so and Win32API.so (for historical reasons,) need to stay in the Ruby lib directories. (And even those 2 mentioned here, should stay in the full Ruby install folders, if possible.)
                      We just cannot copy all of the Ruby extended library files into the Sketchup plugins folder. It will create havoc.
                      • Dan RathbunD
                        Dan Rathbun
                        @moghouse said:
                        main.rb cotains
                        and
                        require 'Qt4'
                        Actually the 'author_subdir/your_ui.rb' file would have statement(s) at or near the top that are:
                        require('!loadpaths')
                        require('Qt4')
                        See my post: [ Code ] Ruby LOAD PATHs script (Win32) : ver 3.0.1
                        πŸ’­
                        • Dan RathbunD
                          Dan Rathbun
                          @moghouse said:
                          I want to track down the files/libraries that are sought by Qt4
                          I do remember seeing a Ruby script that would go through a file looking for require statements, and search each dependency in turn for their dependancies.
                          It would print out a report. Either was something Rick Wilson wrote, .. or something that disro'd with the Full Ruby install.
                          But cannot locate it now.
                          • bomastudioB
                            bomastudio
                            I've found this project....what do u think??
                            (visualruby.net)
                            • Dan RathbunD
                              Dan Rathbun
                              It has nothing to do with Qt4, uses GTK+ and should not work under SketchUp Ruby, as is.
                              You should start a new topic just for this (VisualRuby/Glade) subject.
                                archonmaster
                                I also want to use QT for user interface. Is there any examples?
                                I decide to create thread and execute main loop of QT application in this thread.
                                [pre:g779cno0]DWORD WINAPI mainLoop(CONST LPVOID lpParam) {
                                coreDataStruct * data = (coreDataStruct *)lpParam;
                                int argc = 0;
                                char **argv = 0;
                                data->app = new QApplication(argc, argv);
                                data->app->setQuitOnLastWindowClosed(false);
                                data->app->exec();
                                data->active = 0;
                                ExitThread(0);
                                VALUE cModule_initialize(...) {
                                if (coreData->active == 0) {
                                HANDLE thread = CreateThread(NULL, 0, &mainLoop, (void*)coreData, 0, NULL);
                                coreData->mainThread = thread;
                                coreData->active = 1;
                                return Qtrue;
                                return Qfalse;
                                }[/pre:g779cno0]
                                Thread is created in function cModule_initialize that should be executed in the begining
                                To create window I have this function:
                                [pre:g779cno0]VALUE cModule_createWin(...) {
                                if (coreData->active == 0) return Qfalse;
                                QDialog *dialog = new QDialog;
                                dialog->show();
                                return Qtrue;
                                }[/pre:g779cno0]
                                Is that correct?
