    [Plugin] SectionCutFace
    569 Posts 171 Posters 478.2k Views 170 Watching
      artsnot
      Could my problem have to do with using Podium for Sketchup? When I try using Zorro to cut my model it also crashes immediately.
        You have very few scripts auto-loading from Plugins...
        You could try disabling both Zorro and Podium temporarily - add a ! onto the end of the file extension to prevent it auto-loading on a restart of Sketchup.
        Later on you can remove it back to .rb/.rbs as appropriate, so it enabled again.
        It's strange that you and a few more now and again have issues as it's been around for ages without problems...
        Open Window > Ruby Console when running the SectionCutFace and see if there are any error messages when it fails.
        Also in the Console type $LOAD_PATH [exactly as here] and there should be a list of the folders Plugins [for 'your' scripts] and Tools [for Google's scripts]; are there any other folders listed there that contain .rb/.rbs files ?
        Can you post the SKP that has the issue so we can text it.
        Can you also ZIP the actual script [.rb] and PM it to me so I can check it hasn't somehow become corrupted during your install... by ZIPping it it'll preserve its contents best...
          danylight
          why is sketchup closing when I use the section cut face ?? does anyone experience the same issue ? I used to work with this great plugin, I reinstalled sketchup ( same version as before, 8.0.3161 ) and now it doesn't work anymore...
          I work with OS X 10.6
            No known issues like this 😕
            Have you tried disabling recently installed scripts to see if they are messing with some base class/methods used by this tool - e.g. some scripts have malfunctioning observers, or even ill-advisedly mess with Sketchup 'group.copy' methods etc and can cause such issues...
            • H Offline
              humbertoanastasia
              Hi. First of all, thank you! I've always used this plugin, and it's just wonderful!
              Since last update, though, everytime i try to use it my SketchUp crashes.
              I don't know what to do...
              Any suggestions?
                Any suggestions?
                See the post just before yours http://forums.sketchucation.com/viewtopic.php?p=401294#p401294
                You must have installed something making rogue changes to base-classes/methods...
                  mwm5053
                  I like this plugin great job TIG I have a small question. When applying section cut face it fills in faces where no faces should be, still can't figure what I'm doing wrong
                  6 story high rise.skp
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                  • bmikeB Offline
                    bmike
                    it will sometimes do that depending on how complicated the geometry it has to cut. it happens to me 10% of the time when doing full building sections with framing, floors, timber, steel, etc.
                    edit the group, and select the major area that needs to be removed. it will usually take a few clicks to clean it up.
                      If your section cut is through non-solid objects or overlapping ones, its algorithm isn't clairvoyant - it makes a best guess at what is what. If you choose to keep unfaced edges it makes a manual repair quick and easy.
                      A simple example is to make two cube groups and overlap them in 3d and cut a section through them...
                      How is any tool going to double-guess what you expect to be filled in solid and what to leave as a void if your objects are no pure separated solids?
                      This one very simple version of two overlapping cubes has eight or more possibilities - here are a few [adding more intersecting objects simply exacerbates the complexities and permutations...
                        mwm5053
                        That makes total sense
                        Thanks TIG
                        2011 iMac
                        V2 Twilight
                          kai350191439
                          Thank you so so much !!!!
                            juanchiarq
                            Hey guys, I'm trying to use this plugin but I'm not getting any result, when I move/copy the object after making adding Section-CutFace I get the same one complete without the Section I've made, can anyone help me with this??, thanks.
                              I think you're expecting something this plugin doesn't do nor is it intend to do. This plugin doesn't modify the existing entity it just creates a new one which is the face on the section plane. If you expect to end up with the entity actually cut, you need Zorro instead.
                                juanchiarq
                                Thank you Dave, that worked almost perfectly for me, the only bad thing is that I have to fill every wall to get a black filled effect when I uses de Section Cut, and also when I do a manual cut the SketchUp crash, I don't know why... 😕
                                  Not without seeing your model.
                                  • Y Offline
                                    yi_design
                                    awsome!
                                    • W Offline
                                      whitelock
                                      Hi, I love this tool however I occasionally get a problem when trying to add section cut face. It will sometimes only fill in the faces of a few of the objects, and then some faces are left open. Is this a glitch? has anyone else experienced this and does anyone know a workaround.
                                      Luke
                                        If you are having intersecting objects it can't always double-guess which should be solid and which should be void.
                                        This was discussed not so long ago. http://forums.sketchucation.com/viewtopic.php?p=406295#p406295
                                        It'd be impossible to have an algorithm that'd be right 100% because what you see as solid might be more logically void and vice versa...
                                        If you leave the option ON to keep all edges a manual fix is relatively straight forward.
                                        Sometimes tiny or gigantic objects cause intersection issues too, but that's rare...
                                        • W Offline
                                          whitelock
                                          I have a question, sometimes when using this plugin I take the section view into Layout and when I try and Dimension the section the Dimension tool will not snap to any points around where there is a cut face. Am I doing something wrong?
                                            There are no edges on a native Section-cut, so you can't snap to anything.
                                            The SectionCutFace tool adds edges/faces to the selected Section-cut, but by default unfaced edges will be removed - so set 'Keep Un-Faced Edges'==Yes to keep them.
                                            Also all edges are 'hidden' by default, so they are not there to snap to either - so set 'Hide Edges'==No so you can see them.
                                            Then you should have some edges to snap on to in the Section-cut...
                                            • 28
                                            • 29
                                            • 8 / 29
