    SU2KT 3.17 missing bitmaps
    7 Posts 5 Posters 1.3k Views 5 Watching
    • N
      nickchun
      I have recently upgraded to SU8 Pro at work 😍 but am now having problems exporting to Kerkythea, the dreaded 'missing bitmaps'scenario. 😞 I have looked through past posts on th KT forums but am still none the wiser. I did not have this problem with SU8 free, and I have an Nvidia 9500 GT card. I am also using SU2KT 3.17. This happens if I put the exported files into a folder or just on the desktop.
      Any ideas?
      • tridemT
        tridem
        what about if you put the .xml scene in the folder where the texture are?
        • tridemT
          tridem
          looking better...perhaps is the ";" character in the folder name? you should avoid characters that are not letters and numbers
          • N
            nickchun
            Tridem,
            just renamed the file replacing the '&' with the text 'and'.
            Worked fine.
            Thanks very much, I will avoid the '&' character in my files from now on
            • N
              notareal
              @nickchun said:
              Tridem,
              Worked fine.
              In xml has some reserved characters... better not use those. Ideally, exporter should give a warning, if reserved characters are used or escape them.
              • T
                tomasz
                @nickchun said:
                Tridem,
                Worked fine.
                Thank you for letting me know. Will have a fix for it, when time permits.
                • irwanwrI
                  irwanwr
                  this is why i always love kerkythea
                  they do things with love πŸ˜„
