SU2KT 3.17 missing bitmaps
I have recently upgraded to SU8 Pro at work
but am now having problems exporting to Kerkythea, the dreaded 'missing bitmaps'scenario.
I have looked through past posts on th KT forums but am still none the wiser. I did not have this problem with SU8 free, and I have an Nvidia 9500 GT card. I am also using SU2KT 3.17. This happens if I put the exported files into a folder or just on the desktop.
Any ideas?Thanks
what about if you put the .xml scene in the folder where the texture are?
looking better...perhaps is the ";" character in the folder name? you should avoid characters that are not letters and numbers
Tridem,
just renamed the file replacing the '&' with the text 'and'.
Worked fine.
Thanks very much, I will avoid the '&' character in my files from now on -
@nickchun said:
Tridem,
Worked fine.
Thanks very much, I will avoid the '&' character in my files from now onIn xml has some reserved characters... better not use those. Ideally, exporter should give a warning, if reserved characters are used or escape them.
@nickchun said:
Tridem,
Worked fine.
Thanks very much, I will avoid the '&' character in my files from now onThank you for letting me know. Will have a fix for it, when time permits.
this is why i always love kerkythea
they do things with love
