    Zippo Lighter
    Scheduled Pinned Locked Moved Organic Modelling
    40 Posts 8 Posters 21.3k Views 8 Watching
    • HumpmetwiceH Offline
      Humpmetwice
      Not sure if I understood you right but what I did still made no difference.
      • pbacotP Offline
        I tried this with Fredoscale radial bending. There was no stretching BUT:
        1. difficult to get close fit to the bend. Won't be exact
        2. takes several steps and each processing is slow.
        3. you have to split off the last part and bend it separately then re-join. (when radial bending begins to bend back, it affects the parts you don't want bent)
        4. There were some faces lost in the last bend I did that needed fixing.
        5. wonder if it is appropriate for 3d printing
        Othere suggestions.
        1. the skull outline may not be suited to what you are after. Try a simpler outline (less vertices).
        2. remove the the back face before bending.
        3. Making the lid joint is going to be a chore. You might do that before bending.
        4. further rounding of edges. IDK if you have to do it, but I tried and failed.
          Humpmetwice
          Ok this is my finished design, all are solids but I'm having trouble cutting the lines indicated in the drawing. I just wondering if my computer is to slow or am I doing something wrong?
          Thanks Kurt
          Zippo Cuts.7z
          • pbacotP Offline
            Pretty complex. I don't think my computer can handle that. I tried making the two cutting planes in a solid and trimming the skull= crash.
            EDIT: this is sort of a reminder to quit smoking. Right?
              Humpmetwice
              It crashes mine too, the quit smoking thing was funny!
              • iichiversiiI Offline
                iichiversii
                Crashes for me too
                Bring on the Rain...
                • oganocaliO Offline
                  oganocali
                  I gave this a try using Kerkythea ( I am trying to learn Kerky). I basically texture mapped the skull and bones image onto the lighter (I may have messed up the hierarchy in the process). In Kerkythea I converted the diffuse map to a bump map and added some metalic quality where needed. Not very easy but doable. Having the skp file you can map any kind of image onto the lighter.
                  Skull Zippo-2.skp
                    Humpmetwice
                    [attachment=0:3t3kskt2]<!-- ia0 -->skulzippo.jpg<!-- ia0 -->[/attachment:3t3kskt2]
                    Thanks Ogan, will try it out but think I've settled with a different design.
                      rspierenburg
                      That is a nice simple solution, but I believe the original idea was to be able to cut it with a 3D printer which wouldn't work with a rendering.
                      Has anyone tried to map the skull on to the lighter, then trace it using draw-on-face plugin and then extrude with Joint Push Pull tool? Just a thought.
                      Rob
                      • pbacotP Offline
                        Rob
                        I tested that some. It could probably be done with a simple design. I think the original post design could be recreated in 2d with very few vertices. Add more detail if needed after "mounting" on the lighter.Might get hung up with too much detail. But the design has changed since then.
                        I have not used TOS much. It would be great if the drawing could be transferred from a drawing on a plane to the surface. That would be a great addition to the tools if not already there.
                        • soloS Offline
                          The skull is not the hard part, IMO it's the edges that look filed that poses the biggest obstacle.
                            Humpmetwice
                            Still working on it but this is the design we are going with.
                            Zippo Parts.skp
                              Humpmetwice
                              Finally finished and sending it to shapeways to get printed. I'm excited to see how it turns out!
                                d12dozr
                                Awesome, Kurt!
                                What material did you order it in?
                                http://goo.gl/f7ooYh
                                  Humpmetwice
                                  @d12dozr said:
                                  Awesome, Kurt!
                                  White Strong & Flexible Polished for now to insure everything is right, later on maybe something a little better.
                                  • pbacotP Offline
                                    great job!
                                    How did you end up cutting the lid joint?
                                      Humpmetwice
                                      @pbacot said:
                                      great job!
                                      I made lines where I wanted it cut at and intersecting with faces inside a group. By the way it took for ever to get back to a solid!
                                      • 2 / 2
