    Zippo Lighter
    Scheduled Pinned Locked Moved Organic Modelling
    40 Posts 8 Posters 22.1k Views 8 Watching
    • HumpmetwiceH Offline
      Humpmetwice
      @iichiversii said:
      Ok your going about this wrong, look at the image of the lighter, the skull and bones wiuld be flat if not wrapped around the main lighter, that's how the skull and bones need to be modeled to be wrapped around your lighter, at present I'm not in front of my laptop but if I were I'd model the skull and bones for you, I will try tonight, do you understand what I mean about the flat surface, look at the skull your trying to use, it's curved, so shape bender can't do what your asking it to do, do you need help with modelling the skull and bones onto a flat surface? I can do this for you and have it posted up tonight
      Yes it would be very nice of you to model the skull and crossbones because I am stuck!
      Thanks Kurt
      • numbthumbN Offline
        numbthumb
        This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:lighter.jpg
        Comfortably numb...
          Humpmetwice
          @numbthumb said:
          This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:1bihddj8]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:1bihddj8]
          That looks about what I want but I can't draw a nice enough skull& crossbones!
          • iichiversiiI Offline
            iichiversii
            @numbthumb said:
            This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:40xardmy]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:40xardmy]
            What Numbthumb has illustrated here explains everything iv said, notice how the skull is flat like the images you posted and not like the 3d skull you were trying to use, obviously Numbthumb only put up a quick illistration and more detail like in the images you provided can be added to your model, even before you use shape bender, using the skull and crossbones would not have worked, does this put it into perspective for you? If your not sure ask and I'll explain it further for you with more tuts
            Bring on the Rain...
              iichiversii
              @numbthumb said:
              This is what I had in mind: TOS and JPP - just an eyeballing, but it might give you an idea:[attachment=0:2b38ohpy]<!-- ia0 -->lighter.jpg<!-- ia0 -->[/attachment:2b38ohpy]
              You don't need to draw it of the tip of your head, download an image and import your image into sketchup and simply trace out the skull and crossbones
                Humpmetwice
                Ok this is what I finally have but still can't manage to get the skull to curve around without it stretching.
                Skull Zippo-1.skp
                  iichiversii
                  Ok iv run into the same problem with the stretch, ill play around with it more and see what i can do πŸ‘
                    iichiversii
                    ok heres my suggestion, and it worked for me, after ou get your shape bended stretched version move it up to the original and match up on each other, note where the stretch/bend takes place and slice the original into too parts on that line, with the left side rescale it to 1/4 sizeand reconnect the original, now it may look wrong but shapebend it again and theres your result 😍
                      Humpmetwice
                      Not sure if I understood you right but what I did still made no difference.
                      • pbacotP Offline
                        I tried this with Fredoscale radial bending. There was no stretching BUT:
                        1. difficult to get close fit to the bend. Won't be exact
                        2. takes several steps and each processing is slow.
                        3. you have to split off the last part and bend it separately then re-join. (when radial bending begins to bend back, it affects the parts you don't want bent)
                        4. There were some faces lost in the last bend I did that needed fixing.
                        5. wonder if it is appropriate for 3d printing
                        Othere suggestions.
                        1. the skull outline may not be suited to what you are after. Try a simpler outline (less vertices).
                        2. remove the the back face before bending.
                        3. Making the lid joint is going to be a chore. You might do that before bending.
                        4. further rounding of edges. IDK if you have to do it, but I tried and failed.
                          Humpmetwice
                          Ok this is my finished design, all are solids but I'm having trouble cutting the lines indicated in the drawing. I just wondering if my computer is to slow or am I doing something wrong?
                          Thanks Kurt
                          Zippo Cuts.7z
                          • pbacotP Offline
                            Pretty complex. I don't think my computer can handle that. I tried making the two cutting planes in a solid and trimming the skull= crash.
                            EDIT: this is sort of a reminder to quit smoking. Right?
                              Humpmetwice
                              It crashes mine too, the quit smoking thing was funny!
                                iichiversii
                                Crashes for me too
                                • oganocaliO Offline
                                  oganocali
                                  I gave this a try using Kerkythea ( I am trying to learn Kerky). I basically texture mapped the skull and bones image onto the lighter (I may have messed up the hierarchy in the process). In Kerkythea I converted the diffuse map to a bump map and added some metalic quality where needed. Not very easy but doable. Having the skp file you can map any kind of image onto the lighter.
                                  Skull Zippo-2.skp
                                    Humpmetwice
                                    [attachment=0:3t3kskt2]<!-- ia0 -->skulzippo.jpg<!-- ia0 -->[/attachment:3t3kskt2]
                                    Thanks Ogan, will try it out but think I've settled with a different design.
                                      rspierenburg
                                      That is a nice simple solution, but I believe the original idea was to be able to cut it with a 3D printer which wouldn't work with a rendering.
                                      Has anyone tried to map the skull on to the lighter, then trace it using draw-on-face plugin and then extrude with Joint Push Pull tool? Just a thought.
                                      Rob
                                      • pbacotP Offline
                                        Rob
                                        I tested that some. It could probably be done with a simple design. I think the original post design could be recreated in 2d with very few vertices. Add more detail if needed after "mounting" on the lighter.Might get hung up with too much detail. But the design has changed since then.
                                        I have not used TOS much. It would be great if the drawing could be transferred from a drawing on a plane to the surface. That would be a great addition to the tools if not already there.
                                        • soloS Offline
                                          The skull is not the hard part, IMO it's the edges that look filed that poses the biggest obstacle.
                                            Humpmetwice
                                            Still working on it but this is the design we are going with.
                                            Zippo Parts.skp
                                            • 2 / 2
