    Zippo Lighter
    Scheduled Pinned Locked Moved Organic Modelling
    40 Posts 8 Posters 24.1k Views 8 Watching
    • oganocaliO
      oganocali
      I gave this a try using Kerkythea ( I am trying to learn Kerky). I basically texture mapped the skull and bones image onto the lighter (I may have messed up the hierarchy in the process). In Kerkythea I converted the diffuse map to a bump map and added some metalic quality where needed. Not very easy but doable. Having the skp file you can map any kind of image onto the lighter.
      Skull Zippo-2.skp
      • HumpmetwiceH
        Humpmetwice
        [attachment=0:3t3kskt2]<!-- ia0 -->skulzippo.jpg<!-- ia0 -->[/attachment:3t3kskt2]
        Thanks Ogan, will try it out but think I've settled with a different design.
          rspierenburg
          That is a nice simple solution, but I believe the original idea was to be able to cut it with a 3D printer which wouldn't work with a rendering.
          Has anyone tried to map the skull on to the lighter, then trace it using draw-on-face plugin and then extrude with Joint Push Pull tool? Just a thought.
          Rob
          • pbacotP
            Rob
            I tested that some. It could probably be done with a simple design. I think the original post design could be recreated in 2d with very few vertices. Add more detail if needed after "mounting" on the lighter.Might get hung up with too much detail. But the design has changed since then.
            I have not used TOS much. It would be great if the drawing could be transferred from a drawing on a plane to the surface. That would be a great addition to the tools if not already there.
            • soloS
              The skull is not the hard part, IMO it's the edges that look filed that poses the biggest obstacle.
              • HumpmetwiceH
                Humpmetwice
                Still working on it but this is the design we are going with.
                Zippo Parts.skp
                • HumpmetwiceH
                  Humpmetwice
                  Finally finished and sending it to shapeways to get printed. I'm excited to see how it turns out!
                    d12dozr
                    Awesome, Kurt!
                    What material did you order it in?
                    http://goo.gl/f7ooYh
                    • HumpmetwiceH
                      Humpmetwice
                      @d12dozr said:
                      Awesome, Kurt!
                      White Strong & Flexible Polished for now to insure everything is right, later on maybe something a little better.
                      • pbacotP
                        great job!
                        How did you end up cutting the lid joint?
                        • HumpmetwiceH
                          Humpmetwice
                          @pbacot said:
                          great job!
                          I made lines where I wanted it cut at and intersecting with faces inside a group. By the way it took for ever to get back to a solid!
                          • 2 / 2
