    Help.. can I model this with sketchup ?
    3 Posts 3 Posters 263 Views 3 Watching
      bejoo
      I need an easy lesson on how to model chandeliers? is sketchup the right program to do so?? chandelier.jpg
        How much detail do you need? How's it going to be used.
        You could model it in SketchUp. I would divide it up into components and split it out into sections. For example the strings of beads in the middle section could be copied in an array around the center. You'd handle the rest of it in a similar way.
        Does it have to be a 3D model? Would it work for you to use the image as a face camera component instead?
          You can use Component Stringer by Chris Fullmer for all the "Chains" πŸ˜‰
          [flash=420,315:2i1s6p6d]http://www.youtube.com/v/rE0laoPV_z4[/flash:2i1s6p6d]
          [flash=420,315:2i1s6p6d]http://www.youtube.com/v/_ymYoEHiexg[/flash:2i1s6p6d]
