    Ruby Script to produce Holes Through All Internal Features W
    4 Posts 4 Posters 477 Views 4 Watching
    • W Offline
      wallacejohnston
      diametrically opposed holes THROUGH ALL IN INVENTORIs there a way to drill a hole completely through all internal walls, voids, holes, surfaces without having to resort to individual Intersection "patches" to penetrate every single SURFACE along the way?
      EXAMPLE: From the King's Tomb, deep inside his pyramid, construct a hole upwards and outwards at an unimpeded angle so that the light from "HIS PERSONAL STAR" would shine directly into his Burial Chamber on the date of his birth?
      A continuous hole, through EVERYTHING - walls, passageways, chambers and other interior structures - in One Extrusion without countless, individual Intersect With Model interventions?
      • gillesG Offline
        gilles
        hole on solid, but you need solids.
        http://forums.sketchucation.com/viewtopic.php?t=41582#p368373
          Indeed. Solid Tools would be the way to go, my friend.
          Welcome to SCF, too.
          • mitcorbM Offline
            mitcorb
            Solid tools may be preferable. However, by way of clarification Hole On Solid functions in both Version 7 and Version 8, as Tak2hata adjusted the code. The tool will work on any grouped and closed volume. Feel free to show different.
