    Copy tool --> no preview
    14 Posts 4 Posters 696 Views 4 Watching
    • N Offline
      njeremy2
      Hello everyone,
      I know is useless because this tools already exist but I have created a plugin which copy a component and paste that copy every where you click on your design but I don't know how to have preview before putting the component on the design.
      1. You select the component
      2. launch the plugin
      3. click where you want to put the copy of the component (ex : a mailbox)
      4. push "space" bar to quit the component
      The benefit of this plugin is you don't have to press "CTRL" or reselect the component you want to copy.
      http://img20.imageshack.us/img20/5782/movex.png
      Original tool with the preview before putting the component
      http://img32.imageshack.us/img32/6931/22608080.jpg
      My tool :
      Tool activate, before clicking
      http://img24.imageshack.us/img24/9577/31931110.jpg
      after clicking on design
      http://img401.imageshack.us/img401/6528/66827814.jpg
      But I cannot have the preview like the original plugin. Without this, the accuracy is bad...
      Someone can tell me how to add this preview ? πŸ˜„
        https://developers.google.com/sketchup/docs/ourdoc/model#place_component
        model.place_component(component_definition, true)
        πŸ˜•
        • Dan RathbunD Offline
          Dan Rathbun
          Here is another way which can copy multiple objects (be they components, groups, primitives, or any combination of them.)
          1) Select the component, or the selection contains anything(s) you wish to copy.
          2) Sketchup.send_action("copy:")
          3) Sketchup.send_action("paste:")
          User presses ESC to unselect the copied things. (But the MoveTool is still active afterward.)
          You can clear the selection via Sketchup.active_model.selection.clear() and then reset the original selection if you have first saved it to an array.
          All this can be done with the Edit menu options, or the Copy and Paste buttons from the Standard toolbar, or CTRL+C/CTRL+V shortcuts.
          I'm not here much anymore.
          • N Offline
            njeremy2
            πŸ˜•
            I LOVE YOU !!!
            It works great !!!!!!!!!!!!!!!
            Since monday, I try to find the solution on the observer but it didn't work ... lol
            Just for my personnal culture, what is the observer ? how do you use that ? (I read so many times the pdf and search on the net but I don't understand exactly the purpose)
            I know it use for retrive any change on edge, entities, component ... but what for ?
            Can you give me example ?
            • N Offline
              njeremy2
              Yeah, I think it could be a great solution but the tool i've made is really useful for people who works for making forest on sketchup for example.
              You select your first tree, activate the plugin, and put your tree everywhere you click (like the video game SIMS on computer 😜 )
              BUT I WOULD THANKS TO ALL OF YOU ! πŸ‘
                Dan Rathbun
                I think there is a component spray plugin that you could use to spray trees into a model.
                • N Offline
                  njeremy2
                  yeah ! but it's not only trees πŸ˜‰
                  • N Offline
                    njeremy2
                    I want to put a name on each copy
                    the name is store on that variable : @nameCompo
                    I put that code
                    newCompo = @model.place_component(@composantDef, true)
                    I try
                    newCompo.name = "#{@nameCompo}"
                    but it didn't work
                    I try also
                    @model.place_component(@composantDef, true, "#{nameCompo})
                    didn't work too...
                    Can I have all parameters of "place_component" ?
                      Dan Rathbun
                      There are only 2.
                      And the API is wrong.. the method always returns the model object. (It cannot return the new component instance because there may be many off them.)
                      So instead do this:
                      before = @composantDef.instances.to_a
                      toolset = Sketchup.active_model.tools
                      tid = UI.start_timer(1.0,true){
                        if toolset.active_tool_id != 21013
                          UI.stop_timer(tid)
                          after = @composantDef.instances.to_a - before
                          after.each {|inst| inst.name = @nameCompo }
                      • N Offline
                        njeremy2
                        @dan rathbun said:
                        There are only 2.
                        So instead do this:
                        >     UI.stop_timer(tid)
                        >   end
                        I'm gonna try this now, I will tell you again when it's working πŸ˜›
                        • N Offline
                          njeremy2
                          Dan, if you were a girl, I could fall in love with you !!!
                          It's working !
                          Thanks to Dan and TIG !!
                          If you need a help from me for Sketchup, ask me πŸ˜‰ I'm a professional almost ! lol
                            Instead of a timer, wouldn't DefinitionObserver.onComponentInstanceAdded be better..?
                            https://developers.google.com/sketchup/docs/ourdoc/definitionobserver#onComponentInstanceAdded
                              Dan Rathbun
                              He is a month-old newbie.. I didn't want to go into observers with him yet.
                              • N Offline
                                njeremy2
                                πŸ‘ right ! thanks πŸ˜„
                                not "month-old", I'm "week-old" newbie ! πŸ˜‰
