    [Plugin] SectionByCamera (V0.2) - UPDATED 4 June 2012
    26 Posts 16 Posters 20.0k Views 16 Watching
      pgarmyn
      Hallo everybody, here is my second (public) plugin.
      The plugin gives me an other way of making plans. Especially in those cases where a 3d model is complete. Shadows in Sketchup plans are not very natural. The sun enters by the cutted part of the model. This way of making the section preserves the realistic shadows:
      SketchupSection - SectionByCamera - RenderedSectionByCamera (Twilight + Kerkythea) : CLICK ON IT TO SEE THE COMPLETE IMAGE
      In this file, the image has been combined with vector-drawing (Powerdraft):
      Rendered SectionByCamera (Twilight + Kerkythea)
      It works also on Mac. Thanks Peter (pbacot) for testing.
      For the SketchupTeam : realistic shadows in sections (plan en vertical section) is in my wish list.
      Copyright
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      Version: V0.2-2012.06.04-2113
      Author : pgarmyn
      Type : Tool
      Description :
      This tool places the camera in (near) the sectionplan. The parallel view will section the model (without section cuts active). But the SHADOWS of the entire model will be displayed (if section cuts are switched off). This will produce a plan or section view with realistic shadow information.
      Works with SKetchup 8 and 2013. [highlight=#ffff00:hmyj04s3]NOT FOR Sketchup 2014[/highlight:hmyj04s3]
      The camera-position is saved in a new scene called "SectByCam"
      The generated camera should also work with those renderers :
      • Twilight : OK
      • Kerkythea, with Twilight exporter
      • SU2KT from Tomasz : The camera is moved, outside the model : Doesn't work.
      • Maxwell : shadows not correct, shadows of 'ceilings' are missing. Thanks Peter (pbacot) for testing .
      Installation :
      • unzip and copy the unique file into the plugins directory
      Usage :
      • select a section plan
      • in the context menu : select 'Section by camera' > '.... automatic'
        or 'Section by camera' > '.... define camera distance'
      • switch off the 'section planes' and 'section cuts' (Menu : View >> Section...)
      Known issues:
      The image rendered on the screen is cutted some centimeters before the camera. The distance between this 'cut' and the camera depends of the dimensions of the model. The tools estimates this distance (in '.... automatic'; distance proposed in '.... define camera distance'), if necessary, it can be adapted in the second option.
      If the applied value is to small, the SectionPlane won't be visible after activating the tool. This is also true for faces generated by plugins like SectionCutFace (TIG) or realSection (GWydouw).
      SOLUTION : apply a greater distance in '.... define camera distance'
      History:
      First version V0.1-2012.05.06-1938
      2nd version V0.2-2012.06.04-2059 : Correction for certain non horizontal sections (thanks vidy for reporting the bug)
      IMPORTANT : erase the older version if installed (= file SectionByCam-20120506-1939.rb) ❗
      COPY in the plugin-directory; IMPORTANT : erase the older version if installed (= SectionByCam-20120506-1939.rb)
      • PixeroP Offline
        Pixero
        Thanks, this looks very useful.
        • CadFatherC Offline
          CadFather
          Many thanks pgarmyn.. this is a really good plugin - i was asked this in a recent class and it was not an easy answer.. 👍
            Very neat result! ☀
            • H Offline
              haynesc
              Can I see a video explaining how this works please?
              • pbacotP Offline
                [floatl:wid3noag][/floatl:wid3noag]this looks like a good one. Works in Mac.
                But with Maxwell Fire the result is not correct. The wall shadows are there but the ceiling shadows and ceiling are not. View is not section. Needs more tries to figure out--sort of a half way result.
                Thank you very much for sharing this! 👍
                  Phil Rader AIA
                  thanks I'll give it a whirl
                  http://www.philrader.com
                    mirale999
                    great plugin~! I just wanted this function a few days, for my works to display better~
                    paranoia is a higher form of awareness...
                    • V Offline
                      vidy
                      Dear pgarmyn,
                      thanks for this plug-in, its really good, but i try to do it on section elevation, but it seems won't generate the scene, is it only just for plan view??
                      thanks,
                      vd
                      still so much to learn..
                        pgarmyn
                        @vidy said:
                        Dear pgarmyn,
                        thanks,
                        vd
                        It should work in any direction. What happens? What's your system? What is your Sketchup version?
                        • V Offline
                          vidy
                          Im working with Win XP SP 2, and Google Sketchup Pro 8 M3,
                          it just working fine whenever im doing it at plan view (it generated the scene tab)
                          but when i was try to do sectionbycamera on elevation, it seems don't have any reaction.. (not generated a scene tab)
                          thanks,
                          vd
                            pgarmyn
                            thanks,
                            vd
                            OK.
                            I found out that a section parallel to the red-blue axises doesn't work.
                            I will fix that. Thanks for testing vidy. 😉
                              pgarmyn
                              This PLUGIN has been UPDATED :
                              Look at the top of this page.
                                methade
                                This is my first post. And thank you for this great plugin. Its very very useful for me... Kind regards.
                                  methade
                                  Me again. I am testing the plugin but having difficulties with renderer maxwell fire. It seems its not working. Any help?. Thanks.
                                    pgarmyn
                                    Can't help that. Pbacot had the same experience (see above). I menshioned it in the description.
                                      sepo
                                      Does this plugin work with SU 2014 and btw where is the plugin folder in SU 2014?
                                      • V Offline
                                        vidy
                                        Tested it... and it works like charm
                                        thank you pgarmyn for the update..
                                        regards,
                                        vd
                                          pgarmyn
                                          Sorry doesn't work yet on SU 2014
                                          • mitcorbM Offline
                                            mitcorb
                                            @pgarmyn:
                                            From your first post- as edited: "Works with SKetchup 8 and 2014. NOT FOR Sketchup 2014 "
