[Solved] Recommendations for hosting and CMS?
@ecuadorian said:
Kim: Qtranslate looks good. However, in your example (CSMedia Productions) clicking on a language button didn't take me to the corresponding page in the other language... it just took me to the home page.
Did you try to switch between the two languages...?It's correct that when clicking a flag it's supposed to take you to the front page with the language selected...
IMO it doesn't make much sense it you browse the web-site in Danish language, then when you're on one of the pages, you all of a sudden want to read that specific page in English...?? Why would anyone want to do that...?It can be made so that when you click the flag, it will take you to the corresponding page you're on, but in another language... This is not how I made it, and I don't see the point making it like this...?
When you're on the front page in a specific language, all the pages will remain in that language, so it sure works very well and it's really easy to setup...
Any way... It was just to give you an example...
When you say a multi-language in one site : it's like the google translation or it's a real human translation ?
Seems Weebly has 8 primary languages for build a site
From that I see for the French Part seems translated by a human
(Interface, description, manual etc...)
So when you make a site in French the Interface will be in French!
But a surfer on the site can't switch between languages!
But you can make in 10 seconds the transformation of your site!
As the pro version gives you 10 sites and a function "Copy Site" exist (even on the free version for 2 sites) so...
Just make little links on the Home page of each site when you have made the 8 variations!
Translation of each textes pages is of course an another story!
Google Translator here can help you for this (with all funny results)
or you must have some money for the 7 other languages to do!
Example of my French site about Moment of Inspiration (I have not made 2 versions as shown above)
Works not so bad, even buttons are translated
Alas you can't press on the translated buttons for pop up change page! (Google technic fails
It's mono page! But you can press on the translated links on a page!
And you can play with the Google buttons Original / Translation -
Pilou, I will write the content myself both in Spanish and English. Of course I'll have it checked by a native English speaker.
Perfect! That's exactly what I need, and it's also Google's recommendation:
Consider cross-linking each language version of a page. That way, a French user who lands on the German version of your page can get to the right language version with a single click.
Maybe in some time your site will be translated in no time
[flash=560,315:8x3m5ed6]http://www.youtube.com/v/cQl6jUjFjp4[/flash:8x3m5ed6]
So I decided to follow the advice of Csaba, Rich and Kim and create a WordPress site, instead of listening to Pilou and go with Weebly. So I signed up for BlueHost, which is recommended by WordPress. And you won't believe what I found after loggin in... How ironic. (Bluehost is cheaper than Weebly Pro)
I'll continue tomorrow, it's 2:22am here.EDIT: I ended up watching the video. Now I'm seriously tempted by Weebly. Maybe can just use a folder for the English version and create manual links between corresponding pages. After all, my site will be less than ten pages in each language, so a fully automagic system seems overkill.
Have you already installed WP? If you wish to install it using multisite (would be fine for multiple languages), special installation is needed. Let me know if you need some help.
Well, it turned out to be kind of a bait-and-switch. Bluehost "free" Weebly turned out to be limited to only 6 pages, and to remove this limit you must pay an extra 9 bucks/month. So I'm going with WordPress... But tomorrow. I need sleep.
My sites in free have more hundred pages! http://piloumaison.weebly.com/ and i can add any number of pages!
Where have you seen that ?
Edit
Ah ok passing with the BlueHost options above as tool!
So pass directly by Weebly
Google itself gives it! Or Google Chrome!
What do you want more ?
Update
My bilingual site (sort of) is now ready. Have a look and comment:
http://www.arqui3d.com -
Fonctionnal
What have you used in the end ?
I asked Bluehost for a refund and signed up for Weebly Pro. It's a joy to use!
Thank you, Pilou!
You might consider removing the gmail from the showreel.
That's about the only thing I can say.
Yes, I plan to replace it with an animated logo at the end.
Thanks for reminding me.
Thanks for this thread. I'm putting together a basic WP site and that Theme Forest is great.
Thank you, Pilou!
It's a pleasure
If you want some infos about something problematic, don't hesitate to MP me
With your input, this post could be even better ๐
