    SketchyPhysics - New Grip System for Cars ! !
    16 Posts 6 Posters 3.8k Views 6 Watching
      MrDailyBlah
      @don east said:
      Where did you put this script?
      Don
      u need to put it in the "scripted" section of the Sketchyphysics UI (neither the "ontick" or "ontouch" section would work...)
      • H
        hobbnob
        Hehe not a bad idea, but you could just have put push([0,0,-1]) in the ontick field of the wheel, does exactly the same thing πŸ˜„
        (little extra note, if you want to have the vehicle turn on it's side/upside down and still have it work, then encase your steering block around the drive joint (either hinge or motor dependign on your preference) and they won't collapse)
        My WIP Thread:Here
          MrDailyBlah
          uh..well.. push([0,0,-1]) creates a violent vibration in the wheels.. so its not that simple.. 😞 ❗
          p.s. i looked in ControllerCommands.rb and found the push()method is the same as $sketchyPhysicsToolInstance.pushBody(), which creates the vibration i talked about... 😒
          • H
            hobbnob
            I haven't had that problem in the 4 years I've been using sketchyphysics, you sure you've got your wheels geom and ontick interval set up correctly?
            My WIP Thread:Here
              MrDailyBlah
              sure as pants man.. ❓ ❗ 😲
              • ashscottA
                ashscott
                Yeah I have the same issue with Hobbnobbs micro script - I am building a walking machine - the fluctuation which is somehow included in hobbnobs micro script causes my machine do hover and float around slowly.
                When I implement MrDailyBlah's I get the kind of traction for my machine's feet that I was looking for. Can increase traction by changing the value'-1' in the part of the script that goes in the wheel to '-2'. Nice work
                I've got no idea where the vibration is coming from - funnily enough, the other two variables marked '0' in hobbnobs script control push in a certain direction. You can make your machine/vehicles hover in certain directions using these variables.
                Just some stuff I do with Sketchup.
                • ashscottA
                  ashscott
                  I've added a little complexity that is causing this script to crash SP when I try to run it.
                  As far as I can tell it has something to do with the raytest function - potentailly related to the issue described on this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=30558
                  I have tested it in SU7 as well but am getting the same issue - basically the model explodes, the POV zooms way out and all I can find left in the model is a bunch of endpoints (like on the end of a tapemeasure guide......can anyone shed some light?
                  Ash
                    MrDailyBlah
                    Ash
                    that's right sir...
                    i used raytest to find the point where the wheels touch the floor, then i teleport magnets to them to attract the wheels... πŸ€“
                    • ashscottA
                      ashscott
                      But Raytest has a tendency to cause SU to flip out - know of a workaround or why I am having the symptoms described?
                        MrDailyBlah
                        uh... 😲 nooo...
                        u'd better consult pros like Wacov.. πŸ˜•
                        • ashscottA
                          ashscott
                          So you're not getting the issues I described two posts ago.....?
                          I seem to get it no matter how I run it (apparently the raytest issue was clashing with SU8 but I can't even get it working right in SU7)
                            MrDailyBlah
                            try reinstalling sketchup or SP or sumthing πŸ˜• ...
